Rear wheel bearing check
Old 05-27-2013, 06:20 PM
SoAlVette
SoAlVette's Avatar
Default Rear wheel bearing check
On my 95 coupe, 71K miles, I have been getting the click from the rear end when starting and stopping. Figured it was the the teflon washer. Jacked up the rear, grabbed the tire at 12:00 and 6:00, virtually no movement. At 3:00 and 9:00 I get maybe 5mm movement. Went to the other side, exact same thing. Does that sound okay? Back and forth, I did not notice any unusual movement in the u-joints. Feel pretty good about it, am I wrong?
Old 05-28-2013, 10:48 AM
92ragtop
92ragtop's Avatar
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Mine has the same mileage, and has the same click. All bearings and U-joints are good, so that leaves the washer as the most likely culprit. I plan to leave it unless/until the bearing goes.
Old 05-28-2013, 11:16 AM
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
I don't think the washer causes any click. Most likely ujoint. Sometimes it's hard to tell which one
Old 05-28-2013, 12:20 PM
ejscarfo
ejscarfo's Avatar
Check the half-shaft u-joint closest to the wheel. That was the culprit on my car when I heard that click.
Old 05-28-2013, 06:18 PM
QCVette
QCVette's Avatar
I disagree.
On my '94 they did. I noticed it mainly from a stop when I began moving and especially when I was turning left. (Mine was the left rear washer) It made a clicking noise. I replaced it and the noise was gone.
Try checking this thread. It helped me.
http://forums.corvetteforum.com/c4-t...e-washers.html
Good luck.
Old 05-30-2013, 12:37 AM
Frizlefrak
Frizlefrak's Avatar
Marco has the dreaded click on the left rear. I ordered both washers today. Haven't pulled a rear bearing in a decade....guess it was inevitable.
Old 06-22-2013, 06:50 PM
SoAlVette
SoAlVette's Avatar
Replaced my teflon washers today, while I was in there I replaced all 4 axle shaft u-joints and polished the axle shafts. Not a bad job, only had to make one trip for tools, did not have a 36 mm socket for the hub nut. Cleaned up and polished some of the aluminum frame while I was under there, I'll take some pics and get the posted. Turned out being an all day job, but only because I did a lot of extra cleaning and polishing while I was at it.
I followed quickcat's step by step post, he nailed it. No more click when starting and stopping
Old 06-22-2013, 07:07 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Before you do all that surgery, re-torque the flange nuts to 164 lbs-ft. If the noise continues, be ready to pay for it, or to have a great weekend.
Old 06-22-2013, 07:39 PM
Firewalker11
Firewalker11's Avatar
I am in the process of doing this tomorrow. I tried yesterday but snapped a cheater bar trying to take the 36mm nut off! Now it is soaking with PB Blaster on it. I hope to be able to break it loose and finish, I am tired of hearing the clicking on my 94 coupe
Old 06-22-2013, 08:02 PM
PLRX
PLRX's Avatar
2017 C4 of Year
Go buy an electric impact gun. I had mine for 7 years, and it works like a charm.
Old 06-22-2013, 08:23 PM
SoAlVette
SoAlVette's Avatar
What do you mean, the wheel bearing? When I saw in my service manual that they had to be torqued at 160 , I was a little surprised.
Old 06-22-2013, 08:33 PM
Firewalker11
That is great advice on the electric impact wrench, if I can't break it free tomorrow I will go out and buy one stat!
Thanks!
Old 06-23-2013, 10:28 PM
PLRX
PLRX's Avatar
2017 C4 of Year
I don't know if it is 160, 162, 164. I do know it's not 200. I do have all books regarding a complete overhaul for the 95 and 96.
Try torquing the nut first.
To Rear wheel bearing check
Quick Reply: Rear wheel bearing check
