What are the concerns?
i recently got a nasty crack in the front windshield of my 94 Corvette. the insurance company is covering the damage by replacing the windshield at no cost to us. what are the concerns with having the windshield replaced by a glass company? are there any parts that they may damage, i.e. trim or weatherstripping? is there any prep work anyone recommends prior to the glass company's arrival?
I would shop around to get someone who has experience with replacing C4 galss! I would be afraid of the trim pieces breaking.
Also make sure what they will pay for, I recently had my 2007 Tacoma windshield replaced and wanted factory glass back in it and they said no way because, the aftermarket replacement windshield was $235 and Toyota glass was $900
what did you end up going with? state farm said that i could take it to the dealer and get a quote and if it was over what their books say is fair for a 94 Vette windshield replacement, i would have to pay the difference out of pocket.
I opted for the cheaper one, I didn't want to spend $700 more to get a Toyota one and get it busted again! I did that the first time after I had the truck for 2 weeks and caught a huge rock in it, but back then it only cost me $435 for a factory one. It's a good windshield that Safelite put in, but you can tell it's not factory!
If I were to get a new one for my vette, it would be a factory one.
You'll have to let me know how much more they want for the factory one.
Safelite quoted $395. Got an estimate from a Corvette shop that said Safelite didn't replace all the seals and the metal trim would bend when forced off and would need replacement and are not in production. The windshield seal (that goes across the top and down the pillars is over $400 alone). They said Safelite only uses "goop" and does not replace the trim. The Corvette shop estimate was $1200.
I opted to try "repair" first and will see if it gets worse. Mine was in the lower corner near the dash, so not in view. It is a 94 convertible.
That's what I figured! That's why I would go for a "Corvette Shop" that know's what they are doing, otherwise your trim will get messed up!
I don't think $1,200 is a bad price!
A couple of years ago State Farm replaced mine on my '94 at no charge to me. I used a local shop.
They used a new weatherstrip since the old one was damaged during removal. The weatherstrip (unknown brand) they used was junk. At the front edge of the side windows there was a bulge in the weatherstrip and the windows would not seal against it.
They replaced the weatherstrip with a Willcox weatherstrip and it was much better quality and fit.
All in all, it was a pain getting it repaired. But on the good side, I had a section of the dash that was raising up along the windshield and while the window was out I was able to glue it back down flat again.
Good luck.
Good luck.
Banned Loser
Location: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
ok will do. i'll call t=he company on monday and ask them if they have experience in replacing C4 windshields. the weather stripping is my biggest concern. as of now i have a great seal and a quiet ride and i would like the same with a new windshield.
You guys should just be happy you don't have to find a replacement for the ZR-1 windshields. It's the one part that is truly impossible to find - and if you do find one, they seem to start at $3000 and go up from there. That's one reason a lot of ZR-1 guys are replacing their windshelds with the base Corvette windshields.
ZR-1 windshields have a reflective coating sandwiched in between the glass layers. When the ZR-1 was being developed, GM PT engineering could not find an A/C unit powerful enough to fit the available space (given the large size of the LT5). Since GM has cabin temperature standards that they must meet in a variety of conditions, it was suggested that having a reflective coating on the windshield would reduce the load required by the A/C unit to achieve their standards - and they could thus use a smaller A/C unit. One interesting problem GM ran into during testing was that the reflective windshield did not allow radar detectors to work, so they have a cutout in the reflective coating to allow for the attachment of a radar detector. You can identify the ZR-1 windshields because that have a pinkish hue in sunlight as opposed to the completely clear look of the base windshields.
well the installer will be here any moment. if he has not replaced a C4 windshield before i think i will send him away respectfully. when i inquired about replacing the windshield at the dealer, they too stated that they subcontract the windshield replacement out. only got 2 hours of sleep so far today. had my wife wake me up about 10 and got home form work at 7 and fell asleep somewhere around 8. its already strike 1 as we told the company for a LATE afternoon replacement time, as it would enable me to sleep for a bit and be out there supervising the installer like a hawk during the install. good news is..i guess...the upon inspection of the current windshield, it appears that it has been replaced at some point in the past as the glass is not original.
they got here and couldn't finish the job. the metal window moldings were apparently glued down and since they didn't offer replacements they stopped at that. they tore the upper portion of the windshield gasket and said i need to get the parts and reschedule. i put the window seal back on as best as i could..with a few tears of course... and bolted the top back in place. i called the insurance company and the car is now approved to be taken to the local Chevrolet dealer. i've been talking to Corvette America about their U.S. made rubber window seal and the dealer said they have a source for quality metal window moldings. as soon as they can acquire the moldings and the window seal then i will bring the car down and have it done at the dealer.
