adding a spare tire to a spare delete car??
Old 06-12-2013, 04:45 PM
GonHuntin
GonHuntin's Avatar
Default adding a spare tire to a spare delete car??
Looking at a spare tire delete car (online) and I don't like the idea of not having a spare.
What parts are needed to add a spare to a spare tire delete car??
Do spare tire delete cars even come with a jack??
Old 06-12-2013, 05:02 PM
Nowhere Man
Nowhere Man's Avatar
Received 6,943 Likes on 4,782 Posts
2015 C2 of Year Finalist
spare tire delete cars were cars that originally had run flat tires. so no jack. you would need to remove the cross brace in the back then instal the spare tire tub and tire. the jack goes into the storage compartment beside the radio box. the lug wrench is behind the driver side seat. I am sure you will have no problem finding what you need. as the spare tire delete brace is sought after
Old 06-12-2013, 05:03 PM
don hall
don hall's Avatar
You probably just need a tire carrier that is 'hinged' at one end, and
has a fastening lug-nut sized bolt at the other end. Available from any vette salvage yard. Check to see if the hardware is still there to attach the tire carrier.
Don't know why a spare-tire delete vette would carry a jack and wrench. Probably carried an air compressor and patch kit.
C4 jacks and wrenches are available from the same salvage yards, and ebay.
Old 06-12-2013, 05:04 PM
GonHuntin
GonHuntin's Avatar
Thanks for the info!
Old 06-12-2013, 05:11 PM
aboatguy
aboatguy's Avatar
Originally Posted by seabright
Some confusion here........ C4s did not come with run-flats. The spare tire rested on a tire carrier that was hinged at the rear, and secured at the front end with a 3/4 bolt. The jack was stored in the hub of the spare, and the wrench had secure hardware behind the driver's seat.
FAIL!
Check out the C4 option codes for the later C4s
hint 1995 corvettes could have these options
N84 Spare Tire Delete
UJ6 Low Tire Pressure Warning Indicator
WY5 Tires, Extended Mobility
Old 06-12-2013, 05:15 PM
Nowhere Man
94 RPO WY5 Tires Extended Mobility 2,781; 95: 3,783; 96; 4,685
where as RPO N84 was the spare tire delete
Old 06-12-2013, 05:26 PM
aboatguy
aboatguy's Avatar
I seems the only confusion is with my intellect..........
spare tire delete/extension was a 95/96 option.
and WY5 Tires Extended Mobility commonly called RUNFLAT tires
Old 06-13-2013, 12:05 AM
GonHuntin
GonHuntin's Avatar
A 12 volt compressor and plug kit have gotten me out of a bind a few times, but they won't help much if you damage a sidewall..........
To adding a spare tire to a spare delete car??
Quick Reply: adding a spare tire to a spare delete car??
