95 won't start when hot outside, and inside.
This may be unique here. I just purchased this 95, and have had 3 occasions where it won't crank after sitting in the hot Arizona sun for a few hours. I took it to work Saturday and when I went to leave, it wouldn't start. Won't even crank over. The battery is new and the lights and instruments all come alive. The lights don't dim when the key is turned to start. I went back on Sunday morning, and it started right up.
This just happened again today. This morning it was around 70 when I left, and after 9 hours of sitting, it was around 90 when I went to start her. No crank again, with the lights and all working. I pumped the clutch pedal several times to see if it may be the switch, with no success. I took it out Monday several times, and it always started. It has me baffled. Any suggestions? Happen to anyone else?
Thanks!
Brian
Thanks!
Brian
VATS. Does the "security" light stay on during a no-crank condition?
Try cleaning the pellet on the key with rubbing alcohol. I finally got sick of messing with VATS and bypassed it.
The Security light only comes on and flashes when I open the hatch. Other than that, the light never comes on. But.. it never comes on when it starts, or doesn't start. I had a new key made, and it does the same with either key. How do you disable the VATS?
Generally, during a VATS fault, the security light will stay illuminated when you turn the key. You then have to wait approx 5 minutes before you can attempt restart.
Try turning the key on, and using a handheld remote starter switch. See if it cranks over then. You may have a fault in the starter circuit, solenoid, or motor instead of VATS.
Assuming an auto; try moving gear shift to neutral instead of park when it does not start.
Next thing would be to measure the voltage at the starter solenoid when not starting to determine if voltage is there is there or not. This would eliminate VATS and ignition switch if voltage is present and is then likely the starter needs rebuilt/replacing. If no voltage, then need to determine if VATS or ignition switch is at fault.
Where at in AZ?
Where at in AZ?
I'm in Mesa, AZ. It's still at work this morning. I will take my truck to work and see if it starts now that it's cool. It should. I guess the ignition switch could be the problem, based on it being so hot in the car sitting in the sun during the day. (no covered parking) I'll try a few things, like leave the windows down, put a towel over the steering column to keep the sun off. I'll put it up on ramps this weekend and try the remote starter idea. Hoping to get this fixed. Taking it to Vegas June 13.
Update: It didn't start for the 3rd day. Just sitting at my work. I had it towed to a mechanic I used in the past, near my home. When they unloaded it off the rollback, it started right up. Now, my mechanic has had it for a week, has been using it here and there, and it starts every time. The only thing he did was clean the contacts in the key cylinder for the VATS. But, he also said that if it was the VATS, it would still crank, but wouldn't start. I don't know if that's right. Anyway, he also said the battery cables show some internal corrosion. I am going to have him replace them, get the car back, and see if I can get it to die again, but first I am taking my bicycle to work so I have a ride home. Electrical problems are a PITA.
First off VATS in a 95 is controlled thru the CCM. There is no separate VATS module unlike older C4's.
Second, a VATS or more accurately a PASSkey issue WILL prevent engine crank. I just fixed a 94 with this issue. However, the security light was lit up constantly when the key is in ON or START position.
Make sure your mechanic understands when this was happening (after sitting out in the sun for a while) so he can try and replicate the issue.
If its a PASSKey issue there should be stored DTC's (Diagnostic Trouble Codes) for the CCM. Your mechanic (if they have a half decent scan tool) SHOULD be able to look for these codes or jumper pins 4 and 12 in the DLC and read them via the CCM thru the instrument cluster display.
The car needs to be caught in the act and diagnosed as a no crank. That is the only way its going to get fixed.
Thanks for the information 93Rubie. I'll pass it on to my mechanic. I read on another forum that there may be a problem with the door switches. Since I don't get a "security" light other than when the hatch is open, there may be an issue there. Maybe I will try the bypass from Baker.
Well... it did it again. This time, I had my bicycle at work, so I had a fun 6 mile ride home, in direct sun on my back, and a temp of around 107. I drank a pint of water before I left. I made it home. Now, I picked up the car on Saturday, drove it all around over the weekend with no trouble. I took it to work Monday, and it at in the sun all day. Started at lunch, and quitting time. Same today, but it didn't start at lunch, and not at quitting time. Same condition. All lights on, no crank. I am taking my truck to Vegas for a week, and will deal with this when I get back. Just another crack in the road of my life...
Starter
It turned out to be the starter. I bought a new one from Amazon (Bosch) and installed it myself. Worked fine since then. When it doesn't start, take a hammer and tap the outside of the starter and solenoid. If it starts after that, it is a bad starter. You may also have a problem with the VATS system, if your Vette still has that.
