New weatherstrip doesn't seal
Just completed my weatherstrip install today. There seems to be a problem with the B pillar. With the passenger window rolled up there is a 5-6 in long slit that I can easily slip a piece of paper through. I would expect this to be a major leak. The window seems to be exactly like the other. I don't think there is an adjustment for this anyway.
The other side seals fine
Vender has not replied to email sent a noontime today.
I could probably put something in back of the rubber to back it to puff out more, but why should I have to?
Hope you can see in the pics
You need nice soft weatherstrips Original GM is best but very expensive, the only other choice is Willcox.
If the weatherstrips are too tough it will not flex to absorb the side window shape, you can adjust the windows to the top tilts in more but not the lower parts.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Not everything is perfect. So rather than buying another set of rubbers, why not back this set up like you observed?
The gaskets will shift and set after time but an air gap is not likely to "close up" by itself.
Who said they were not from Wilcox?
Looks like maybe the weatherstrips went directly from the "packaging" directly to the car. It will sometimes/most times help if the weatherstrips are laid out in at least room temperature for a day or two. Laid out in the sunshine for a few hours would/should also improve an install.
Location suggests it likely was rather cool maybe even "cold"!
Wilcox has a good reputation, I'm sure they will backup the problem if it turns out to be a defect with the weatherstripping. I've seen lots of weatherstipping post over the years, and yours is the first I've seen with this problem.
Could just be a defective piece and I would be surprised if Wilcox didn't offer to replace the piece.
The weatherstrips came in a box and I don't think going straight on the car has anything to do with it. Being in the sun may make them easier to work with but won't make them puff out more in order for the correct seal.
my garage looks cold, LOL. How did you come to that conclusion from the pictures?
UPSTATE NY I would think should be pretty "self explanatory" I assumed nothing about your garage! If your "location" is "fictitious" maybe I should have asked first BUT I'll stay with what I mentioned about being laid out and room temperature helping!
I'd think maybe even Wilcox does "Holidays"!!!
my weatherstrip experience
steve
Not sure why some think upstate NY is cold this time of yr. Average temp is 70 for this time of yr
Average? Sure! I'd also say this hasn't been "typical" - you "might" also notice I mentioned "cool" AND MAYBE "COLD"! The past 3 or so days have been more March like than May here locally and from the looks of the weather maps "UPSTATE NY" might have been similar! From "stuffed" in the box directly to the car your experience isn't out of the ordinary!
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There are lots of things that can affect the door glass fitment to the weatherstrip.
One area to look at would be the window lateral adjustment pads not being positioned properly, If the pads are worn it will allow the glass to move outward at the top, (remember when adjusting the pads, if you push on the glass at the bottom with the pad, it will push the top in. In this same sense, if they are worn they will allow the glass to tilt outward.
Regulator or bushing slop can also cause these same issues. If the regulator to glass bushings worn or loose on the glass, the glass will seem to have a mind of its own and be next to impossible to seal to the rear weatherstrip.
If the hinge pins are worn the door will drop and pull down the top of the glass, this makes for a miss-match in the radius from the glass to weatherstrip.
Sure it’s possible to have a defective rear weatherstrip but the quick way to check this is to remove the side section and allow it to relax (if it’s been on the car the area where the glass has been pushing will be slightly collapsed). Once relaxed, see if the thickness of the weatherstrip is the same where the glass has been hitting vs. where it is not. If the thickness is the same then the issue is not the weatherstrip but rather the glass adjustment or door.
IMHO,
Willcox.
IMHO,
Willcox.
IMHO,
Willcox.
IMHO,
Willcox.
IMHO,
Willcox.
IMHO,
Willcox.
