Check engine light
Old 05-09-2013, 04:46 PM
marky48170
2nd Gear
marky48170's Avatar
Default Check engine light
Ok, I need to read codes (if there are any) but my CEL is burned out. First off how hard is it to replace the bulb, do I need to tear the dash apart, second could I use a test light to count the flashes instead of the CEL?
Old 05-09-2013, 06:16 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
Go to Autozone, (etc.)...they'll pull the codes for you.
Old 05-09-2013, 09:08 PM
marky48170
2nd Gear
marky48170's Avatar
Rather do it myself because the car is iffy.
Old 05-09-2013, 11:13 PM
lt4obsesses
lt4obsesses's Avatar
What year is the car. There is the paper clip method, of which I'm not an expert, or you can get a reasonably priced code reader at the autoparts store for either OBDI or OBDII.
Replacing the bulb imagine is just a matter of taking the dash front cover off.
Old 05-10-2013, 01:03 AM
Cliff Harris
Cliff Harris's Avatar
What year is the car? It does make a difference.
It's a "Service Engine Soon" light, SES for short. ...At least that's what it says on my car.
Old 05-10-2013, 03:24 AM
xrav22
xrav22's Avatar
You need to remove the tilt wheel lever and take out the screws on the front panel. There are a few by the door vent . After the dash panel is off just remove the middle panel and the unit itself the bulbs are right there .Piece of cake.
To Check engine light
Quick Reply: Check engine light
