Turn signal short in tilt column
Old 04-25-2013, 10:20 PM
Frapps
Frapps's Avatar
Default Turn signal short in tilt column
Working on a 92 for a friend, he complained that the right turn signal sometimes didn't work. Today while I was trying recreate it, I discovered that the signal worked with the tilt wheel all the way up and would stop whenever I lowered the wheel. I was able to get it to work a little as I slowly lower the wheel, stopping every fraction of an inch or so.
So something in the column is loose or worn out. Would someone please point me in the right direction on what to look for? And is this going to be easy or should we seek expert help?
Bruce
Old 04-25-2013, 10:31 PM
1993C4LT1
1993C4LT1's Avatar
Because I have the same problem.
Quick Reply: Turn signal short in tilt column
