Heat/Sound Deadeners On Sale **STARTING @ $109.99**
Old 04-07-2013, 11:06 PM
0corvettemods1
Former Vendor
corvettemods1's Avatar
St. Jude Donor '12-'13
Default Heat/Sound Deadeners On Sale **STARTING @ $109.99**
With driving season fast approaching, its time to finally do something about the heat build up from your undercarriage and that droan of exhaust and road noise.
Our complete CNC cut deadener material will create a liner of protection reducing noise and interior temperatures. We have 2 new choices depending on your goals for your Coupe or Vert.
Our ensolite material offers a well-rounded approach to your heat/sound quenching needs. This lightweight material offers great sound killing properties and can lower inside temps 15-20 degrees.
ON SALE $139.99
CLICK HERE TO ORDER:
http://www.corvettemods.com/C4-84-96...ts_p_5565.html
Finally, our advanced kit offers a foil-lined backing and an extra thick middle for the maximum heat/noise blocking. This material carries a R-19 rating!
ON SALE $149.99
CLICK TO ORDER:
http://www.corvettemods.com/C4-84-96...it_p_8119.html
Don't forget to add the door kit too!
http://www.corvettemods.com/C4-84-96...ge_p_5566.html
corvettemods1 is offline
Old 04-29-2013, 05:14 PM
shakedown067
shakedown067's Avatar
Does this include the transmission hump? While I've got most of the interior out, now would be a good time to insulate it. Is there much weight difference between the two?
shakedown067 is offline
Old 04-29-2013, 05:46 PM
0corvettemods1
Former Vendor
Yes, it does. No material weight from this mod.
Old 06-17-2013, 10:40 PM
roadcaqpt
roadcaqpt's Avatar
heat no concern, BUT how much sound reduction from your kits, my 95 coupe is like a soup can!!!!
roadcaqpt is offline
Old 06-17-2013, 10:41 PM
0corvettemods1
Former Vendor
If you go with the advanced kit, it makes a huge difference!
Old 09-18-2013, 11:50 AM
CVTLOPE
CVTLOPE's Avatar
How is the kit installed??
ie, Does it go on, under, or in lieu of current material?
CVTLOPE
CVTLOPE is offline
Old 09-18-2013, 12:56 PM
0corvettemods1
Former Vendor
CVTLOPE
Hi
It replaces the material under your carpet. However you can always put it on top of the deadener for even more dampening
Old 03-28-2014, 11:28 AM
67Olds442x2
67Olds442x2's Avatar
Originally Posted by corvettemods1
Hi
Just so you know, I got the advanced foil sided kit and you would not be able to double up on the stock pad. It would be too thick. This kit by itself under the carpet will be plenty enough. Have I tested it out, not yet, but I've pulled out all my old stuff and this new pad would not go over the old stuff and then carpet on top. Seems very good so far.
67Olds442x2 is offline
Old 06-01-2014, 11:36 PM
Barchetta
Barchetta's Avatar
I installed this kit throughout the whole cabin, including the door panels. It is a very inexpensive upgrade that everyone should do. I highly recommend it. It's easy because the pieces come cut to fit. The stereo acoustics are much improved, road noise decreased by at least 30%. Doors close with even more of a solid 'thump'! Much more cost effective than the Dynamat product.
Barchetta is offline
Old 05-06-2015, 02:09 PM
0corvettemods1
Former Vendor
Old 05-06-2015, 02:30 PM
starrman62
starrman62's Avatar
Which one is $109.99?
starrman62 is offline
To Heat/Sound Deadeners On Sale **STARTING @ $109.99**
Quick Reply: Heat/Sound Deadeners On Sale **STARTING @ $109.99**
