Replacement Jamb Switches
Looks like my '90 needs at least one new jamb switch. I tried pulling the plunger out with a flat-head screwdriver and spraying with WD40. The courtesy lights went off, and I thought the problem was fixed. Unfortunately, I got home after a long weekend away to find the battery completely dead.
Any idea where I can buy new jamb switches?
Thanks.
Thanks.
Thanks.
Thanks.
If so you can likely get away with shimming out the door jam where it hits with a piece of foam to help the plunger go in and turn off the light.
Otherwise check out some online catalog dealers for a replacement plunger switch. Be ready for a real workout. It's not easy to change. It's buried inside the door frame.
