Dropping my nuts
Dropped a spark plug socket on the passenger side. Found it about 10 years later when I removed the head while replacing a head gasket, it was neatly tucked into the motor mount.
My C4 still has a brand new spark plug between the starter motor and the block. While trying to retrieve it, I could touch it with the end of my fingers but could never get hold of it. Had to make a trip to AutoZone for one plug!
Thought this was one of those "old man" posts. Dropping nuts isn't that bad, sitting on them kinda sucks though.
Whenever possible, I stuff rags in any openings below my work area to catch any nuts, bolts, wrenches, etc. that I will definitely drop while doing the job.
in the process of pulling the engine on my 84 and found this sucker wedged under the fuel lines on the front crossmember. it looks to have been there for years and i have no idea where it came from:
Hey, I dropped a stainless razor blade into the water jacket in the engine block while scrapping the water pump gasket. I spent 8 hrs fishing and searching. It's been in there a year with not one single issue. Lol
