How do I remove headliner from targa top
Old 02-23-2013, 06:40 PM
JUSBAD
JUSBAD's Avatar
Default How do I remove headliner from targa top
What exactly needs to be done to remove the headliner from the targa top, my headliner is sagging and I am going to replace it.
Old 02-23-2013, 07:10 PM
jtownc4
jtownc4's Avatar
There is about a 1/2" thick piece of rigid insulation that the fabric is glued to. It is then glued to the underside of the roof. No clips or trim... I used a putty knife to work the edges of the insulation loose enough to get my fingers under it and I started pulling, it all came off in one big piece. It left some chunks of the insulation where the spray glue was thick, then I scraped the chunks off as well....
I decided to not replace my insulation in favor of a little more much needed extra headroom. I glued my new headliner material right onto the underside of my roof panel, and if you didn't know it had insulation there from the factory, you could never tell it wasn't supposed to be the way I installed mine. There is even a little lip the whole way around that I was able to tuck the edge of the headliner material under for a suprisingly professional looking job.
If you wanted to reinstall the insulation, you would wrap it in headliner material, then glue it back up in...
Old 02-23-2013, 07:13 PM
WW7
WW7's Avatar
The headliner foam is glued to the fiberglass top. It would have to be separated from the top with something slid between the foam and top. I used a putty knife on one that worked pretty well. Once the old fabric is removed and the new headliner material is glued on the foam the foam is then reglued back onto the top. There is a spray adhesive specially made to secure the fabric to the foam called "headliner adhesive" and this is the best glue to use for this job .....WW
Old 02-23-2013, 07:43 PM
BSenzina
BSenzina's Avatar
I have an 84 and mine is held in place by 5 or 6 velcro strips. I just gave it a pull.
Old 02-23-2013, 09:46 PM
Speedjester
Speedjester's Avatar
I just pulled it down. Sanded it down smooth to remove the glue and help the paint adhere ...Then I painted it a satin black...looks great and I have extra headroom
Old 02-24-2013, 09:21 AM
WGlen C4
WGlen C4's Avatar
I took the material off because mine was sagging when I bought the car. I scraped down the foam until it was level and them applied headliner glue. I let the glue dry on the foam and also on the fake leather that I was mounting. after an hour I sprayed both again and applied to the foam. Worked great but I am going to put a rolled vinyl bead around the outside of the pleather. I tried to use black with a red pleather strip down the center but you need a special sewing machine to sew that stuff well.
I kept the foam because I heard that it cut down noise and heat from the sun on the roof panel.
I have pictures of mine but can't post them on here.
To How do I remove headliner from targa top
Quick Reply: How do I remove headliner from targa top
