LT-1 to LT-5
LT-1 to LT-5
Crazy thought, but I seen this LT-5 on flea bay, if one wanted to swap out the LT-1 will the LT-5 bolt right up? 92 vert
http://www.ebay.com/itm/1992-Corvett...7c1854&vxp=mtr
If you are serious about doing that swap. IMO you'd be better off going to the CF ZR1 section where a ZR1 is being parted right now due to body damage and buy the drivetrain, computer, wiring harnesses etc et al. I believe just buying that engine on Ebay is going to cost you beaucoup $$ in odds and ends to make it work in your car.
IE accessory drive isn't shown in that picture. Are the ASR Traction control etc (pathways) the same between LT1 and ZR1, valet key, is the LT5 ecm plug and play in your vette or is that another wiring harness you need to procure, etc?
Have fun.
Mike
Have fun.
Mike
This has been discussed many times. I've had to put one back together from nothing and had three apart.
Trust me, you're better off just buying a real ZR-1.
