Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C4 Corvette Discussion not covered in Tech
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-17-2013, 03:48 PM   #1
Mohammed_z
CF Senior Member
Mohammed_z's Avatar
Mohammed Al Nasri 94vette
Default Lights flickering problem , video inside
I don't see other problems in the car , but the flickering itself is annoying if I think about it, or just keep looking at the dash playing with idle to see if it's gone or not.
What are possible things that cause this flickering ?
Mohammed_z is online now   Reply With Quote
Old 01-17-2013, 04:38 PM   #2
eaglevision993
CF Senior Member
eaglevision993's Avatar
Send a message via ICQ to eaglevision993 Send a message via Skype™ to eaglevision993
Hi,
I had a similar problem that was caused by a the wire going to the positive battery connector.
But the most common cause is the voltage regualtor in the alternator. I replaced the battery and alternator just to find out that my problem was only a loose connection so check the easy and cheap stuff first.
Does it only flicker with the engine running?
Best regards
Benjamin
eaglevision993 is offline   Reply With Quote
Old 01-17-2013, 05:09 PM   #3
Mohammed_z
CF Senior Member
Mohammed_z's Avatar
Quote:
Originally Posted by eaglevision993 View Post
Hi,
Best regards
Benjamin
Yes , only when the engine running. I hope it just a cheap fix !!
Old 01-17-2013, 05:53 PM   #4
mrmtrtrnd
CF Senior Member
Support Corvetteforum!
mrmtrtrnd's Avatar
My dash lights flicker just a little and have from the day I bought the car. I agree with 993 that the most common problem is the regulator but not the only cause. I don't know what parts cost there but if it is the alternator it shouldn't cost to much. Hope it is a easy and cheap fix.
Forgot to add if it is the regulator inside the alternator you can buy that part and change it your self without buying the entire alternator.
mrmtrtrnd is offline   Reply With Quote
Old 01-17-2013, 07:07 PM   #5
eaglevision993
CF Senior Member
Could also be a loose ground somewhere, but have the alternator and battery checked out.
A weak battery may also cause this.
Old 01-18-2013, 01:46 AM   #6
Mohammed_z
CF Senior Member
Mohammed_z's Avatar
That's a good idea , I will try to search for the regulator. Thanks
I will test them both , but does a bad regulator drains the battery ? Because I dont feel the battery is weak !
Old 01-18-2013, 01:52 AM   #7
DinoBob
CF Senior Member
Please check the terminal block behind the battery, where all the hot feeds are connected. Mine was in need of replacement. Gladi caught it. Could easily have led to a fire. Same symptoms.
DinoBob is online now   Reply With Quote
Old 01-18-2013, 01:56 AM   #8
Mohammed_z
CF Senior Member
Mohammed_z's Avatar
Quote:
I don't know which terminal you're talking about , do you mean the small fuse box ?
Old 01-18-2013, 04:57 AM   #9
Mohammed_z
CF Senior Member
Mohammed_z's Avatar
Is it ok if I installed a higher amp alternator ?
Old 01-19-2013, 01:21 PM   #10
Mohammed_z
CF Senior Member
Mohammed_z's Avatar
Default Update
UPDATE
I removed the alternator , replaced the voltage regulator and the laminated core.
Started the car and the flickering is still there. I think I just wasted some money and I should replace the rectifier now , if i'm not mistaken !!!! , I'm an electrician I know the rectifier has diodes and I didn't have a multimeter to check it , took it to a car electrician and after a while he told me it's fine. It doesn't need to be replaced !!
voltage regulator
Click the image to open in full size.
core
This is a pic of a rectifier , but it's for another car (just to show how it looks) it's almost the same.
Old 01-19-2013, 01:23 PM   #11
DinoBob
CF Senior Member
Did you check the terminal block?
Old 01-19-2013, 01:24 PM   #12
DinoBob
CF Senior Member
Check behind the battery for it. It is almost right up against the firewall. All the hot feeds run to it.
Old 01-19-2013, 01:26 PM   #13
Mohammed_z
CF Senior Member
Mohammed_z's Avatar
There is a small fuse box there !! Do I need to remove the battery to see this terminal block ?? Can you show me a pic of that ?
Old 01-20-2013, 10:19 AM   #14
mrmtrtrnd
CF Senior Member
mrmtrtrnd's Avatar
Sorry my bad in my first post I should have added start with connections first then move to the regulator. While the regulator is a common problem so are faulty connections like bad grounds. They are the source of many electrical problems in these cars. I'm trying to trace down a problem in my car and in doing so have found corroded connections and some corroded fuses like I've never seen before. These weren't my problem but would have caused issues in the future.
Old 01-20-2013, 02:21 PM   #15
Mohammed_z
CF Senior Member
Mohammed_z's Avatar
Are you having the same issue ?
I'm trying to figure out the terminal that DinoBob mentioned but I'll have some time next weekend so I change the rectifier and search for this terminal.
Old 01-20-2013, 07:51 PM   #16
mrmtrtrnd
CF Senior Member
mrmtrtrnd's Avatar
No I'm having a completely different problem on my car. The engine runs good but intermittently dies. It's been a real pain to find the problem but I think I'm closing in on it.
Reload this Page Lights flickering problem , video inside
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Flickering Ammeter ctuinstra C3 Tech/Performance 10 05-02-2014 09:29 PM
Electrical problem, high beam flicker Surfer69 C3 Tech/Performance 14 11-04-2013 10:09 AM
Older HID Low Beam Flickering AnteVenom C5 Tech 1 08-17-2013 12:45 AM
lights flickering?? glasguydj C5 Tech 4 12-31-2012 02:03 PM
78 Vette - Headlights flicker WTF 78stan C3 Tech/Performance 3 12-17-2012 10:22 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
