Make hood release emergency cables now
Old 01-17-2013, 03:25 PM
Kmcoldcars
Kmcoldcars's Avatar
Default Make hood release emergency cables now
If you have not done so you should make hood release emergency cables now. It took me about 1/2 hour and some plastic tubing and stainless steel wire I had around the house. I also had to drill 2 small holes.
I also cleaned old grease out of the hood latches and put some new grease in. It is much easier to pull the hood release handle under the dash now.
How one looks with the hood closed. It is very hard to see from outside the car with the hood down. Remember, they do not have to look perfect. If you need them, you should only have to open the hood once with them before fixing the hood release.
With the hood up.
Old 01-17-2013, 03:58 PM
GreyGhost
GreyGhost's Avatar
Nice job
A long black zip tie works very well and takes all of 3 minutes to do
Old 01-17-2013, 05:59 PM
Allentown Ernie
Allentown Ernie's Avatar
I did mine years ago using the long "chicken bands"--- "zip ties".
Old 01-17-2013, 06:13 PM
mrmtrtrnd
Support Corvetteforum!
mrmtrtrnd's Avatar
[QUOTE=Kmcoldcars;1582865553]If you have not done so you should make hood release emergency cables now. It took me about 1/2 hour and some plastic tubing and stainless steel wire I had around the house. I also had to drill 2 small holes.
This is something that should be posted from time to time for the new members and can be a life saver.
Old 01-17-2013, 06:22 PM
ckwhite
ckwhite's Avatar
Originally Posted by GreyGhost
Nice job
Oh yeah...And so easy. And if that doesn't work out, I'm building myself one of those steel rod hoodd latch tools like the one the guy used on mine to get it open. Believe me: NOTHING worse than that feeling in the pit of your stomach when your hood won't release!
FrankieD
FrankieD's Avatar
There is much more secure way of opening your hood latch instead of having to install emergency cables that gives thieves potential access to your engine compartment Every C4 owner should have this tool in their vette as a necessity. Easy and secure
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
Old 01-17-2013, 06:53 PM
Cruisinfanatic
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
Afraid the engine will be stolen?
Old 01-17-2013, 07:08 PM
kimmer
kimmer's Avatar
C4 of the Year Finalist
When mine broke I looked online how the tool looked and made one. After that I installed the emergency release's.
Old 01-17-2013, 07:47 PM
nathanours
nathanours's Avatar
I've got some zip ties and steel wire, and need to do this. I've got a couple hours of time free tonight. Anyone got a good set of directions on exactly what needs to be done?
Old 01-17-2013, 11:30 PM
gerardvg
gerardvg's Avatar
Did mine a few years ago
Old 01-17-2013, 11:47 PM
desertmike1
desertmike1's Avatar
Nice job
I need to get on this.. do you have a pic by chance?
Old 01-18-2013, 12:13 AM
nathanours
nathanours's Avatar
Perfect, thanks, I'd also like to see the zip tie method as well. I'll have to do this tomorrow after work. I'll probably do wire though in case something catches on fire so it wouldn't melt.
Old 01-18-2013, 12:21 AM
higgyburners
higgyburners's Avatar
I believe in the Beer Fairy
St. Jude Donor '15,'19
I have mine
Old 01-18-2013, 12:40 PM
jimmymack
jimmymack's Avatar
St. Jude Donor '09-'10-'11,'13-'14-'15-'16-'17-'18-'19-'20-'21,'22-'23-'24
Old 01-18-2013, 12:52 PM
Jbws86928
Jbws86928's Avatar
St. Jude Donor '13
I used zip ties. I will try and get a pic later.
Old 01-18-2013, 09:53 PM
jmgtp
jmgtp's Avatar
Plastic zip ties can become weak and brittle with age and repeated heat cycles. Could break when you pull on them.
I used stainless wire from my MIG welder. Regardless of what you use, better to have something in place just in case.
Side tip: if you do this mod it's also a great time to clean out the drain pockets where the hood pins are. My car carried a pool of water in each when I bought it. Years of muck clogging the drains.
Old 01-19-2013, 09:29 AM
mickey5
mickey5's Avatar
I used 50# test fishing leader which is rust proof plastic coated wire with a snap on one end that clips on the release lever. Use an awl or pocket screwdriver to pierce a hole in the rubber gasket and push the swivel on the other end of the leader through the hole. You can get the leaders in 12 to 24 inch lengths. A couple of bucks gets a packet of them.
I agree that zip ties get brittle with age, especially in the cold weather and can break with very little force applied.
To Make hood release emergency cables now
Quick Reply: Make hood release emergency cables now
