Window Tinting
Old 01-14-2013, 10:34 AM
J W Drew
J W Drew's Avatar
Default Window Tinting
I plan on having my 85 windows tinted soon. Currently, the tint is blue however, over the years has turned to a purple hue. The car is two tone white with bronze lower section and bronze targa so I plan on going with a brown tint.
Any suggestions, horror stories, ect. It's my understanding they have to remove the hatch glass which concerns me.
Thanks, JW
Old 01-14-2013, 11:12 AM
Jbws86928
Jbws86928's Avatar
St. Jude Donor '13
Thanks, JW
I am trying to bring up a pic of my tinting. I was not around for the tinting so I can't help you there. I like the look and function.
Old 01-14-2013, 11:26 AM
Goldcylon
Goldcylon's Avatar
Thanks, JW
The purple is due to being cleaned with ammonia products like windex over the years and time. The rear hatch glass does not need to be removed unless you are looking for a one piece install vs strips. Grey usually is the WTG. GC
Old 01-14-2013, 12:13 PM
MRPVette
MRPVette's Avatar
There is no need to remove the rear hatch even if they one piece it all they have to do is remove the struts.
Old 01-14-2013, 12:17 PM
J W Drew
J W Drew's Avatar
What cleaner do you suggest?
JW
Old 01-14-2013, 12:25 PM
c4cruiser
c4cruiser's Avatar
JW
A tint shop will give some good advice on how best to clean tint film. I use warm water with just a very small amount of car wash soap. Another thing that works is Stoner's glass cleaner. Groit's Garage has a window cleaner that works with tint film and does a very good job.
Old 01-14-2013, 12:47 PM
Jbws86928
Jbws86928's Avatar
St. Jude Donor '13
This is great to know Thanks
Old 01-14-2013, 01:07 PM
Jbws86928
Jbws86928's Avatar
St. Jude Donor '13
Found it, thanks for the tip on the window cleaners
Old 01-14-2013, 01:31 PM
MRPVette
MRPVette's Avatar
For cleaning use sprayway glass cleaner you can get it at home depot.
Old 01-14-2013, 04:02 PM
mrmtrtrnd
Support Corvetteforum!
mrmtrtrnd's Avatar
Go with a high quality tint. The cheaper tints can turn purple over time even if you use the right kind of cleaner.
Old 01-14-2013, 06:27 PM
Goldcylon
Goldcylon's Avatar
JW
Anything without ammonia in it
Old 01-14-2013, 06:30 PM
Goldcylon
Goldcylon's Avatar
The last three C4 I have had done in one piece install the glass was removed each time. Can it be done??? Yes but it is easier for the tech to remove the glass and turn it over to work.
Old 01-14-2013, 09:14 PM
ckwhite
ckwhite's Avatar
Yeah. No reason to remove the hatch.
Old 01-15-2013, 09:25 AM
Sherryd
1st Gear
Sherryd's Avatar
I agree with mrmtrtrnd, higher quality tints will make the difference between fading and otherwise. I work at a tint shop and the standard or lower grade films will turn purple over time due to the fact that they are made from a DYED polyester material... no manner of cleaning or care will ever protect you fully from that. It's merely age, wear, and sun exposure that contributes to the fading. Even covering your car and keeping it in the garage when you're not using it will not protect it ENTIRELY from fading.
The brand we normally use, 3M, has a very popular "Color Stable" film that is non-metalized and non-dyed, therefore guaranteed not to turn purple. It is probably the favorite among our customers. Any tint types above the color stable in price are also guaranteed not to turn purple. I am not familiar with other brands so I am not sure what their equivalents would be. Despite this, you still should avoid cleaning your windows with an ammonia-based cleaner.
Sources (where I work):
Auto Trim Design of Mid Maryland
ATD Solar & Security
ATD Solar & Security Commercial
To Window Tinting
Quick Reply: Window Tinting
