Quote:
Originally Posted by wilcar
Kind of looks like an edel. carb to me. The distributor (HEI) does not seem to have a vacuum can on it?? Maybe it is on the other side. You really should be using a pre computer controlled vacuum advance distributor with the carb set up if your HEI is not one. Some guys use the computer HEI and not sure how that can give decent performance. The 4309 Mallory FPR is a good unit but I know there are a few on thi s forum that say that if you still have the high pressure in tank pump the 4309 may not handle the excessive pressure for very long. I have the 4309 FPR on my 84 but my stock pump only puts out 14 psi.
That's a picture of my engine, not the OP's.
The picture is from a couple of years ago.
I have a vacuum advance distributor on it now, although it ran fine with the old one.
Gas mileage averaged about 25 mpg highway and the engine seemed to pull pretty good with the stock HEI.
I don't race (street or track) so there wouldn't be any way for me to compare the difference between the two
distributors and how they work.
I've had it on there for the past two (2) years with no problems.
