84 corvette serpentine belt removal
Old 12-27-2012, 04:58 PM
84VetteMan205hp
84VetteMan205hp's Avatar
Default 84 corvette serpentine belt removal
i cant seem to find the bolt on the tensioner
Old 12-27-2012, 06:16 PM
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
to release the tension, you stick the 1/2 in end of a socket wrench in the end and pull or push. No bolt
Old 12-27-2012, 06:21 PM
pmihaltian
Slingshot
pmihaltian's Avatar
All belt tensioners work the same way. You simply put a 1/2" ratchet into the 1/2" slot and then turn the ratchet to loosen the tensioner and allow the belt to be removed.
When installing the tensioner itself, put your socket on the attaching bolt and remove the long bolt that goes into the block. See attached photo.
Old 12-27-2012, 09:27 PM
84VetteMan205hp
thx now on to my journey replacing the water pump.
Old 12-27-2012, 10:42 PM
BSenzina
BSenzina's Avatar
Maybe a dumb question, but I gotta ask. When changing the belt, remove the tension and just swap belts??? Or are there some sort of marks on the belt and tensioner I need to line up???
Old 12-27-2012, 11:16 PM
Cliff Harris
Cliff Harris's Avatar
Just swap. I find it easiest to release the tension and then unhook the belt from the alternator pulley. The manual tells you to use a breaker bar, but I always use a 1/2" ratchet because the breaker bar hits things before the tension is released. I have even pushed down on the tensioner with my hand to relieve the belt tension.
The tensioner does have a mark on it, but it's supposed to tell you when the belt is stretched and needs to be replaced.
To 84 corvette serpentine belt removal
Quick Reply: 84 corvette serpentine belt removal
