Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C4 Corvette Discussion not covered in Tech Sponsored by
Marc Heitz Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-10-2012, 10:30 PM   #1
Enteringmidlife
Junior Member
Default Impossible items to find
Serious, fun or just venting:
What items for your C4 have been impossible for you to find?
Ill start, I have an 87 convertible and 2 items elude me
1. Retrofit kit for hardtop conversion
2. A good condition 3rd brake light lens
What's your needle in the haystack (sort of speak)?
Enteringmidlife is offline   Reply With Quote
Old 12-10-2012, 10:36 PM   #2
93Rubie
CF Senior Member
93Rubie's Avatar
ZF6 Driveline Components. That don't suck.
Ie. Flywheels, Clutch Disc, Throw Out Bearings, Pressure Plates,Master Cylinders, etc...
Unless its really high priced NOS OEM or High priced aftermarket stuff its junk. Even SPEC. is questionable from many experiences I've read/heard about. McLeod is good but bring $$$$.
The lack of QUALITY replacement Opti-Sparks. Lots of cheap ones, FEW quality ones.
93Rubie is offline   Reply With Quote
Old 12-10-2012, 10:56 PM   #3
Klondike
CF Senior Member
Klondike's Avatar
NO KIDDIN'
I've heard stories about new clutches flying apart because they are now made of some inferior ChinaMetal! You can't find a flywheel that really fits except the Fidenza (sp) aluminum one that I hear is great for performance but tough to drive on the street without stalling or bucking.
I'd like to see some headers that actually bolt on a 96 that didn't cost an arm & leg or you didn't have to beat all to hell and saw up a bunch of brackets to make fit.
I know they made a million Mustangs and only a few thousand Vettes, but you would have thought somebody would have stepped up for Chevy’s Flagship performer!
Klondike is offline   Reply With Quote
Old 12-10-2012, 11:10 PM   #4
phlounda
CF Member
phlounda's Avatar
Non Bose dash speaker grilles for 87
phlounda is offline   Reply With Quote
Old 12-10-2012, 11:43 PM   #5
corvetteronw
CF Senior Member
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Support Corvetteforum!
corvetteronw's Avatar
Quote:
You can make those our of fabric from a fabric store or simply remove yours and paint them with flat black paint and then replace them.
corvetteronw is offline   Reply With Quote
Old 12-10-2012, 11:46 PM   #6
corvetteronw
CF Senior Member
Cruise-In VIII
I retrofit a hardtop to the 87 I used to own. I did a writeup and it is in the stickies.
PM me and I will be glad to tell you how to do this.
You can find good used parts and great service from Jason at www.vette2vette.com
Old 12-11-2012, 12:29 AM   #7
Enteringmidlife
Junior Member
Default Hardtop
PM sent, any help would be greatly appreciated.
Thought of a 3rd item, for an 87 the passenger side valve cover grommet is a 90 degree elbow, havent been able to find one of those either.
Old 12-11-2012, 01:33 AM   #8
vader86
CF Senior Member
vader86's Avatar
The cigarette lighter, female end of it that goes into the console panel, not the actual lighter ****.
Regular ones you find at the store will not work. The connector on the back is different, and Ecklers/MAD nor the rest had them when I last went looking.
vader86 is offline   Reply With Quote
Old 12-11-2012, 01:38 AM   #9
silverja
CF Senior Member
silverja's Avatar
Default A Few Others
I believe the following could be added to the list:
Front windshield replacement molding
Rear antenna exterior grommet
Original magnesium valve covers (One side may still be available)
Non-Bose rear speaker grill covers
__________________
John Silverio
'87 Corvette Convertible (Purchased in 2001)
silverja is offline   Reply With Quote
Old 12-11-2012, 01:39 AM   #10
Cliff Harris
CF Senior Member
Cliff Harris's Avatar
I need a molded rubber hose that goes from the throttle body to the tube that goes to the passenger side valve cover. It carries filtered air for the PCV system.
I had to buy a used hose that connects the oil cooler to the block. It was over 20 years old.
Cliff Harris is offline   Reply With Quote
Old 12-11-2012, 07:42 AM   #11
WW7
CF Senior Member
WW7's Avatar
Im having trouble finding a 25 yr old, 5'9" , 120 lb blonde to put in my passenger seat....But I will keep looking........WW
WW7 is offline   Reply With Quote
Old 12-11-2012, 07:42 AM   #12
CCarter8192
CF Member
CCarter8192's Avatar
1993-96 horn switches from inside the steering wheel
Parts been discontinued, checked Chevy dealer, told me there isn't one in any dealer in the us. Even contacted delco to see if they had one laying around. No luck
Checked all the standard after markets vendors with no luck either
Had a corvette salvage tell me he had a good one but wanted 100 bucks for it simply because he knew I couldn't get it anywhere else... I replied with "where I come from, that's simple price gouging, he could keep it"
Gm pt no. 17999094
Ac part no. D1774a
CCarter8192 is offline   Reply With Quote
Old 12-11-2012, 07:45 AM   #13
Halister
Junior Member
Halister's Avatar
I have a pair.
Halister is offline   Reply With Quote
Old 12-11-2012, 07:58 AM   #14
CaledoniaBrian
Junior Member
CaledoniaBrian's Avatar
Quote:
Most golden Retrievers do not live that long.
CaledoniaBrian is offline   Reply With Quote
Old 12-11-2012, 08:39 AM   #15
ricasso
CF Senior Member
Quote:
Or grow that tall.
ricasso is offline   Reply With Quote
Old 12-11-2012, 09:13 AM   #16
dukeallen
CF Senior Member
dukeallen's Avatar
Try the library, under "fiction"
dukeallen is offline   Reply With Quote
Old 12-11-2012, 09:48 AM   #17
IAFF alumni
IAFF alumni's Avatar
1. OEM power antenna assembly
2. OEM magnesium valve covers
3. OEM fuel injector covers
All this for a 1992 LT1 coupe.
IAFF alumni is offline   Reply With Quote
Old 12-11-2012, 09:57 AM   #18
eutu1984
CF Senior Member
eutu1984's Avatar
https://www.facebook.com/eugene.tuorto
How about a brand new C68 programer.
eutu1984 is offline   Reply With Quote
Old 12-11-2012, 10:36 AM   #19
TTA579
CF Senior Member
TTA579's Avatar
tta579
A decent mechanic.
TTA579 is offline   Reply With Quote
Old 12-11-2012, 11:07 AM   #20
92ragtop
CF Senior Member
92ragtop's Avatar
OEM tire air.
92ragtop is offline   Reply With Quote
Reload this Page Impossible items to find
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
