cleaning the aluminum intake
Old 11-15-2012, 12:12 PM
howardjm
howardjm's Avatar
Default cleaning the aluminum intake
what is the best way to clean the aluminum intake on my 89?
Old 11-15-2012, 12:38 PM
NuckinFutz93
NuckinFutz93's Avatar
Is it on or off the car?
Old 11-15-2012, 12:42 PM
howardjm
howardjm's Avatar
Default intake
it is on the car
Old 11-15-2012, 02:35 PM
Larry/car
Larry/car's Avatar
If it is only oil stained, a paint prep cleaner, oil/wax remover works good. Oxidized, a fine steel wool followed by the paint prep cleaner.
Old 11-15-2012, 03:14 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
Depends on the look that you're after.
As stated above, if greasy/oily, start with a strong degreaser. I prefer brake cleaner. Kicks **** over anything else, IMO.
Then, if you're after a "polished" look, the steel wool mentioned above works, as does sand paper (fine grit) which can lead to a polished look.
If you're after STOCK looking, then the only thing that will REALLY clean cast aluminum and keep it looking stock is an etching aluminum cleaner. Look for an "etching aluminum wheel cleaner" for cast wheels (not coated wheels) at your parts store. Spray it on, let sit, blast with water. Repeat of necessary, but it makes any cast aluminum surface look like it just came from the foundry. Awesome stuff.
Old 11-15-2012, 03:36 PM
silverja
silverja's Avatar
Default Thanks
Thanks for the great advice!
To cleaning the aluminum intake
Quick Reply: cleaning the aluminum intake
