Build sheet?
On top of the gas tank. But good luck getting it out without destroying it.
You can also order a reproduction of the build sheet and window sticker from the Corvette museum.
https://store.corvettemuseum.com/ser...buildsheet.asp
And if you did after 25 years of road grime almost impossible to read
There is also usually one inside the front X members as well , sure to be in a worse state
Nice clean '96 shown , yours may not look so good
