California Air Resource Board EO List
If you live in California, you live under the often-oppressive thumb of the Air Resource Board (CARB). Most of us wonder what CARB has approved for the C4 Corvettes and sometimes what we might be able to sneak by a nosey visual inspector with a similar EO number. Unfortunately CARB does not list EOs by vehicle, making it difficult to find the information you may be looking for. I haven't seen a list for C4s anywhere else, so I did the research, and I have a preliminary list.
Notes:
"92" TPI dates are intended for F-Body cars.
"96" is often omitted from the EO due to OBD2 integration for that year.
Part numbers are repeated when parts were sold under different mfgr. names.
Sortable Excel file:
http://dl.dropbox.com/u/48274937/CARB%20EOs.xlsx
Text dumped into the thread for search purposes:
Notes:
EO# EO Date Mfgr Name Device Device Type Part Number Corvette Years Engine
D-216 4/10/1995 Automotive Engineered Products Inc Shorty Headers Exhaust System/ Modification 1810 84 Crossfire
D-234 4/15/1993 JET Performance JET Performance chip ECU / PROM 18415, 18416 84 Crossfire
D-234 4/15/1993 JET Performance JET Performance chip ECU / PROM 38414C, 38115C 84 Crossfire
D-287 9/15/1992 Automotive Digital Systems SuperChips ECU / PROM 8407CA 84 Crossfire
D-287 9/15/1992 Automotive Digital Systems SuperChips ECU / PROM 8408CA 84 Crossfire
D-216 10/13/1994 J Bittle Performance Shorty Headers Exhaust System/ Modification 1810 84 Crossfire
D-234 4/15/1993 JET Performance JET Performance chip ECU / PROM 18516, 18517 85 TPI
D-234 4/15/1993 JET Performance JET Performance chip ECU / PROM 18613, 18614, 18615, 18616 86 TPI
D-234 4/15/1993 JET Performance JET Performance chip ECU / PROM 18706, 18707 87 TPI
D-234 4/15/1993 JET Performance JET Performance chip ECU / PROM 18817, 18819 88 TPI
D-234 4/15/1993 JET Performance JET Performance chip ECU / PROM 18906, 18907 89 TPI
D-234 4/15/1993 JET Performance JET Performance chip ECU / PROM 19015, 19016 90 TPI
D-234 4/15/1993 JET Performance JET Performance chip ECU / PROM 19115, 19116 91 TPI
D-234 4/15/1993 JET Performance JET Performance chip ECU / PROM 19215, 19216 92 TPI
D-287 9/15/1992 Automotive Digital Systems SuperChips ECU / PROM 9222CA 92 Lt 1
D-287 9/15/1992 Automotive Digital Systems SuperChips ECU / PROM 9223CA 92 Lt 1
D-234 4/15/1993 JET Performance JET Performance chip ECU / PROM 19317, 19318 93 TPI
D-216 4/10/1995 Automotive Engineered Products Inc Shorty Headers Exhaust System/ Modification 1817 96 Lt 1
D-260 2/11/2004 Hypertech Power Programmer III ECU / PROM 365652 1996 Lt 4
D-260 2/11/2004 Hypertech Power Programmer III ECU / PROM 365762 1996 Lt 1
D-396 11/16/1994 Summit Racing Twisted Wedge Cylinder Heads Cylinder Head TFS-31400003, 84-86 TPI
D-40 1/16/1997 Autotronic Controls MSD Pro Billet Corvette Tach Drive Distributor Distributor 8572 84-86 TPI
D-442 11/24/1997 Napa Balkamp Shift Rite Device Transmission / Transmission Modification 1 6801 WNC 84-89 TPI
D-215 4/3/1997 Edelbrock 52mm Throttle Body Throttle Body 3803 85-88 TPI
D-215 4/3/1997 Edelbrock 58mm Throttle Body Throttle Body 3804 85-88 TPI
D-221 7/10/1992 Automotive Controls Corp High Flow Billet TB Throttle Body HFBTB 74190 85-88 TPI
D-221 7/10/1992 Automotive Controls Corp High Flow Billet TB Throttle Body HFPIR 74195 85-88 TPI
D-245 12/31/1997 BBK Performance Specialists 52mm Throttle Body Throttle Body 1534 85-88 TPI
D-245 12/31/1997 BBK Performance Specialists 58mm Throttle Body Throttle Body 1536 85-88 TPI
D-235 11/13/1991 Tuned Port Induction Specialties Inc (TPIS) TPIS Fast-Pak Fuel System Modification 100-111 85-89 TPI
D-187 8/20/1997 SLP Flowbooster Air Cleaner Modification 22100 85-91 TPI
D-216 4/10/1995 Automotive Engineered Products Inc Shorty Headers Exhaust System/ Modification 1810 85-91 TPI
D-216 10/13/1994 J Bittle Performance Shorty Headers Exhaust System/ Modification 1810 85-91 TPI
D-235 11/13/1991 Tuned Port Induction Specialties Inc (TPIS) TPIS Throttle Body Air-Foil Fuel System Modification 100-001 85-91 TPI
D-235 11/13/1991 Tuned Port Induction Specialties Inc (TPIS) TPIS Adjustable Fuel Pressure Regulator Fuel System Modification 100-002 85-91 TPI
D-319 4/10/1995 Callaway Callaway Tubular Exhaust Manifold Package Exhaust System/ Modification 85-91 TPI
D-516 8/29/2001 Street and Performance Electronics Inc. Helix Power Tower Air Filter / Intake Modification 57020 85-91 TPI
D-520 8/29/2001 Evergreen Performance PowerAid Throttle Body Spacer Air Filter / Intake Modification 200-522 85-91 TPI
D-609 8/24/2006 Airaid PowerAid Throttle Body Spacer Air Filter / Intake Modification 200-522 85-91 TPI
D-221 7/10/1992 Automotive Controls Corp SuperRam Manifold Base Intake Manifold SMB 74197 85-92 TPI
D-221 7/10/1992 Automotive Controls Corp SuperRam Plenum Runner Kit Intake Manifold SMB 74196 85-92 TPI
D-266 7/7/1992 Nitrous Oxide Systems Inc Nitrous Oxide Injection Kit Nitrous System 5170, 5170-II 85-92 TPI
D-301 1/21/1993 Arizona Speed and Marine Inc TPI Runners Intake Manifold 85-92 TPI
D-187 9/4/1997 SLP Engineering Inc High Flow Intake Runners Intake Manifold 20004 89-91 TPI
D-215 4/3/1997 Edelbrock 52mm Throttle Body Throttle Body 3805 89-92 TPI
D-215 4/3/1997 Edelbrock 58mm Throttle Body Throttle Body 3806 89-92 TPI
D-221 7/10/1992 Automotive Controls Corp High Flow Billet TB Throttle Body HFBTB 74191 89-92 TPI
D-221 7/10/1992 Automotive Controls Corp High Flow Billet TB Throttle Body HFPIR 74199 89-92 TPI
D-245 12/31/1997 BBK Performance Specialists 52mm Throttle Body Throttle Body 1537 89-92 TPI
D-245 12/31/1997 BBK Performance Specialists 58mm Throttle Body Throttle Body 1539 89-92 TPI
D-235 11/13/1991 Tuned Port Induction Specialties Inc (TPIS) TPIS Fast-Pak Fuel System Modification 100-116 90-91 TPI
D-287 9/15/1992 Automotive Digital Systems SuperChips ECU / PROM 9022CA 90-91 TPI
D-442 11/24/1997 Napa Balkamp Shift Rite Device Transmission / Transmission Modification 1 6800 W 90-91 TPI
D-266 7/7/1992 Nitrous Oxide Systems Inc Nitrous Oxide Injection Kit Nitrous System 5172 90-94 Lt 5
D-323 7/21/1994 Doug Rippie Motorsports ZR-1 Engine Package Engine Modification/ Engine Change 90-94 Lt 5
D-319 4/10/1995 Callaway Callaway Tubular Exhaust Manifold Package Exhaust System/ Modification CTEXM-CZR1 90-95 Lt 5
D-333 5/16/1994 Lingenfelter Performance Engineering 530 CID ZR-1 Engine Package Engine Modification/ Engine Change 90-95 Lt 5
D-391 3/6/1995 Callaway Callway Honker Air Filter / Intake Modification CH57-CZR1 90-95 Lt 5
D-269 11/5/1997 K+N Filtercharger Air Filter / Intake Modification 57-3019 90-96 Lt 5
D-187 11/17/1997 SLP Engineering Inc Exhaust Headers Exhaust System/ Modification 30056 91-95 Lt 1
D-215 9/30/1997 Edelbrock ECU Calibration ECU / PROM 2107 92-93 Lt 1
D-333 9/27/1993 Lingenfelter Performance Engineering Lingenfelter 383 CID LT1 Engine Modification/ Engine Change 92-93 Lt 1
D-365 5/19/1997 Accessible Technologies Inc Procharger Supercharger Supercharger System / Supercharger Modification 30092 92-93 Lt 1
D-266 7/7/1992 Nitrous Oxide Systems Inc Nitrous Oxide Injection Kit Nitrous System 5174 92-94 Lt 1
D-164 11/30/1998 Hooker Industries Inc Super Competition Exhaust Headers Exhaust System/ Modification 2061 92-95 Lt 1
D-182 4/30/1997 Walker Manufacturing Company (Tenneco Inc) Headers Exhaust System/ Modification 87724, 88724 92-95 Lt 1
D-213 7/25/1995 Vortech Engineering Inc A-Trim V-1 Gearcharger System Supercharger System / Supercharger Modification 92-95 Lt 1
D-215 4/3/1997 Edelbrock 52mm Throttle Body Throttle Body 3807 92-95 Lt 1
D-215 4/3/1997 Edelbrock 58mm Throttle Body Throttle Body 3808 92-95 Lt 1
D-216 4/10/1995 Automotive Engineered Products Inc Shorty Headers Exhaust System/ Modification 1815 92-95 Lt 1
D-231 9/26/1996 Whipple Industries Inc 8 PSI Whipplecharger Supercharger System / Supercharger Modification WIK5701, 5701P WIK5701-1, 5701P-1 92-95 Lt 1
D-235 6/6/1995 Tuned Port Induction Specialties Inc (TPIS) TPIS Z-28 Kit Engine Modification/ Engine Change 92-95 Lt 1
D-245 12/31/1997 BBK Performance Specialists 52mm Throttle Body Throttle Body 1540 92-95 Lt 1
D-245 12/31/1997 BBK Performance Specialists 58mm Throttle Body Throttle Body 1542 92-95 Lt 1
D-301 12/6/1991 Arizona Speed and Marine Inc 52 & 58 mm Throttle Bodies Throttle Body 92-95 Lt 1
D-319 5/6/1993 Callaway SuperNatural LT1 (383 cid) Engine Modification/ Engine Change 92-95 Lt 1
D-319 4/10/1995 Callaway Callaway Tubular Exhaust Manifold Package Exhaust System/ Modification CTEXM-CLT1 92-95 Lt 1
D-391 3/6/1995 Callaway Callway Honker Air Filter / Intake Modification CH57-CLT1 92-95 Lt 1
D-411 8/7/1996 Gibson Performance Products Headers Exhaust System/ Modification 1815 92-95 Lt 1
D-424 4/30/1997 Dyna-Flex Products Headers Exhaust System/ Modification 1815 92-95 Lt 1
D-187 8/20/1997 SLP Flowbooster Air Cleaner Modification 21050 92-96 Lt 1
D-396 11/16/1994 Summit Racing Twisted Wedge Cylinder Heads Cylinder Head TFS-31400004 92-96 Lt 1
D-439 6/1/2004 Pacesetter Marketing Inc PaceSetter Exhaust System Exhaust System/ Modification 70-1340, 72C1340 92-96 Lt 1
D-323 7/27/1994 Doug Rippie Motorsports 400 Series Engine Package Engine Modification/ Engine Change 93-94 Lt 1
D-471 1/23/1999 Granatelli MAF Air Filter / Intake Modification 350111 93-95 Lt 1
D-215 9/30/1997 Edelbrock ECU Calibration ECU / PROM 2109 94-95 Lt 1
D-225 10/31/1995 Crane Cams Compucam Camshafts Camshaft 2040, 2050 94-95 Lt 1
D-427 4/5/2001 Northern California Diagnostics Labs Hyperspeed Controller ECU / PROM n/a n/a
Received 3,043 Likes
St. Jude Donor '05
I'd like to find this head.....
changing the heads on the '84 are a massive improvement over stock. The hot tip has always been get a set of '87 and paint them black for visual......but since there is a "CARB" approved set....I wonder if Summit would ever make them.
St. Jude Donor '05
AFR 180 and 195s I believe are CARB legal
CARB/BAR sticker for engine swap
Im just wondering if you get the crate LS3 engine from GMMP and put 2011 smog equipment. Can I tell the state referee that its a 2011 and get a CARB/BAR sticker on the car?
Well...not practically. That's essentially what GM has done with the EROD series, collected together a set of components and worked with the CARB/BAR to have it tested and certified with an EO. I don't think that level of testing is within the scope of the referee's job function---he wants the smog values targets to already exist (the donor vehicle limits or EO values) and inspects to be sure they are met. If you collect components then you would have to work with the CARB to define the limits before the referee can do his thing. I'm no expert, but doubt this is practical for an individual.
