What do you dislike about the C4?
#121
#122
I wish either the top had a quick release, or had T-tops. Cheap plastic cracking interior parts, and the glitchy digital climate control module('88 here). highway drone of the knockoff flowmasters
#123
Hey Guy--love to see it again some time. By the time I passed the car along to you I had completely taken care of the missing problem. The thing is my mechanic and I never quite figured out what was causing it but the problem went away after he did the rocker install along with upgrading the spark plug wires.
#127
There is nothing that I dislike about my "Please arrest me red" 1994 Corvette. I get more looks than a drugged up rock star parading around on top of a building and can knock down over thirty miles per gallon on the highway. What is there that is not to like??
#130
Some rattles
Targa top is a chore to remove
Brakes to puny by todays standards.
Door panels starting to peel away
#132
the oil temp gage on the 96 LT4's makes no sense. the only time it reaches 205 degrees is when there is a heat wave. The gage doesn't begin to register until 215 degrees. The needle never enters the gage.
#133
#134
Pro Mechanic
Really? What cars had better performing brakes in '78? Not many.
#135
Car & Driver Road Test of the 1984 Corvette:
"Item: Its braking, thanks to an advanced Girlock four-wheel-disc system, makes the car stop as if it had been dropped into a sand bank. Our 70-to-0-mph brake test produced a stop in a mere 173 feet — seven feet shorter than the best 1982 distance of 180 feet, recorded by a Porsche 928, and not far off the all-time record of 165 feet, set by a Porsche 930 Turbo!"
Article: http://www.caranddriver.com/reviews/corvette-road-test
#137
The C-4 Corvettes
Ha! This is my 1st corvette and I love everything about her! Ya there are always little thing to take care of and service. But ha! The is one hella of a ride.
#138
That's a fantastic color, too!
I wonder if all these complaints about the brakes aren't possibly the result of a lot of the cars' brake systems no longer being "stock". By this I mean pads/rotors no longer genuine GM-spec parts, master cylinders/calipers/ABS controllers not working properly, rubber hoses aged into mush, old fluid, tires of incorrect-equivalency, etc. All of these variables can tend to wander away from spec over time on most multi-owner used cars. People will try to save money on a repair that's needed in order to sell a car, or maybe they were just cheap with all the car's needs all along. I don't see why the brakes on a car that has been kept, or brought back to, original specification shouldn't work just like the brakes on that Car & Driver test car did...
#140
For my 87 my dislikes are -
1. 4+3
2. Wish the seat would go back more
3. Could use a cupholder
4. My foot often catches the floorboard when I use the clutch.
I have more likes than dislikes...
1. 4+3
