Oil Leak
Okay got the car to start and run on first crank but how do I reset service engine light now? (light came on when car was dying from oil satuation of opti spark) Everything has been replaced so I should be good to go - excapt for light comming on
Assuming the battery was disconnected during the recent repair, that would have cleared the codes and no light should be present. Did you try to start the car before you had all the sensors/wires reconnected? If not, you have a new code or codes that you need to retrieve and trouble-shoot.
oil leak
ooops,
My bad - I DID not take off battery while doing repairs - I know, I know should of, would of, could of - but I did not disconnect battery.
On another note, before I started car, ALL wires hoses etc. were hooked up - with no parts left on bench. The service engine light came on BEFORE I started repairs when car was sputtering and finaly not working on side of road. So I think it is a code that was stored BEFORE Corvette engine tear down 101 started.
Is there a way to just clear codes and start fresh. I saw on forum if I disconect battery and turn on headlight switch (?) it would clear codes. I gave trhat a whirl to no avail.
Thanks in advance for ANY input.
Jim "service engine soon" Sawyer
ooops,
Disconnecting the battery will not work on a '95....you will need to get a OBDI/II code reader/scanner....to reset the PCM. AutoZone and other places will come out to your vehicle, pull the code and clear them...for free.
I ended-up just buying a code scanner off of ebay...have used it many times and on other cars.
oil leak
Okay here is the deal - codes cannot be reset by pulling a fuze - not happening. They need to be reset by a obd1 code reader, plain and simple.
I took my car to Speed Secrets in Snohomish Wa and it took Ellis Grove about 2 sec to find the prob. Vacum line lose
JIm Sawyer
Got the car running agin yahoooooo
JIm Sawyer
