C4 owners. Look under your hood!
[/QUOTE]
Perfect picture of them! I drilled a 1/4" hole right down through the middle of the large hole where the locking pin goes in. The water drained right out. No more collecting of water in them.
Received 5,011 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
NOW I understand!
Went and checked mine, both are dry. I'll keep an eye on that from time to time, thanks for the heads-up!
Great shot!
Now if you remove the Hood latch plates by removing the three bolts (Mark & maintain positions) the plates lift right out, at this point, the Cavities below the plates can be cleaned, and drain openings checked. You can also lube the underside of the latch plates.
I would Avoid drilling, metal chips and untreated (drilled holes) will rust!
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
These are old news.
Drill a hole...or buy the Mid America kit.
Location: St. Louis, Mo......... 1993 Torch Red w/White Interior...2006-07 Bloomington Gold 2005-ZR1/C4 Gathering, 2001-2012 Funfest
I drilled into the bottom of mine and added the drain kits.
This should have been done from the factory.
GEEEZ! I felt this was a pretty good post for those of us who didn't know of this potential problem, and a possible way to correct it. There are obviously a few here here who know it all and feel it's not neccessary to post such dumb things. Is there a place here to check in with you before we post?
My 93 did not have any drain holes on either side.
Both sides held water until I installed the drain holes.
#33
What do you think the "factory installed holes" are? HOLES! What's the difference? I couldn't find any factory holes in mine. One extra hole drilled into it isn't going to destroy the car. The new drilled hole would be visible to you but not noticable enough through the big locking pin hole that it would ruin anything and it would only take about 5 seconds to clean it out from time to time if neccessary. Maybe some would prefer to spend 20 minutes to take the entire thing apart and disengage the cable just to clean the clogged up "factory hole". It doesn't make good sense to me though. 5 seconds compared to 20 minutes. Simple.
#35
Can anyone post a pic of the back hatch area referred to earlier in this post? I would appreciate it.
Later,
Lee
Later,
Lee
#36
My early '86 has the holes there and no sign of rust anywhere. Perhaps Bowling Green omitted the holes on some later models for some reason.
#38
Good, just pop up the rear glass, and in each lower corner you'll find the water pooling in there. I just use a turkey baster to suck up the water then dry it. I'm either too cheap, scared or lazy (not sure which) to drill the holes and install the drain kit
#40
Thanks for the heads up. I was not aware of this issue and will check my 86 out to make sure there is no water pooling in the hood latch area. As far as the rear hatch area I did notice water pooling there when I washed the car. I just dried it out with a super absorbent towel. I too am afraid to do any drilling in the rear hatch area. If i find water in the hood latch area, I will drill a hole if there is none or clean out the hole if there is one there.
Once again thanks for posting. There are those of us who recently purchased our C4s (bought 3 years ago from my dad) and thought informed, we don't know everything about them, so this kind of info is always helpful to us.
