Need someone smarter than me
I noticed a leak(cooling Fluid) under my 90 vette.
I topped off the cooling fluid,started the car and let it get hot.
And I looked for a leak.. no leak
After 2 days of sitting cold.. the leak starts again.
What leaks on the cooling system when the car is cold but not hot?
Thanks for any input
Sam
Sam
The usual way I learn how to fix my C4 is by f'n it up the first time and then doing it right after I figure out what I did wrong. So I don't claim to be very smart.
I read about this is a recent auto magazine. Looks like it might work for your situation:http://www.google.com/products/catal...d=0CLoBEPMCMAE
Best advice I have is to clean everything very well then look for the leak. I had a leak from the plastic sides of my radiator, but it was the opposite of yours (leaked when really hot).
Rent a pressure test kit from you local auto parts store. Also test you radiator cap.Look a your coolant cap an pressurize the system to that spec. Now look for leaks and get back to us.
Thanks guys
Am I understanding this correctly?
If my coolant cap was faulty ,after a day or two coolant might leak out the waterpump weep hole?
Much like water stays in a drinking straw if your finger plugs the top opening.
'90s are notorius for weeping coolant at the intake manifold gasket in the rear corners. I've had mine doing this for 20 years...it dribbles a little on the floor every now and then. It's easier to wipe it up than replace the gaskets.
So is it coming from the weep hole?
GL with that.
http://forums.corvetteforum.com/c4-g...-cylinder.html
That is exactly what happened to my 1990 a few years ago. And I had heard at the time that this was a problem with 1990's. I had a blown head gasket at the #7 Cylinder (which is where this usually happens). Had to have the top-end of the motor rebuilt. I started a thread when this happened and included alot of pictures. I was loosing coolant and it got progressively worse until I started seeing steam come out of my exhaust. Here is a link to the thread.
