Test drove a 95, overheated during test drive??
Ok, been gone a long time, looking to buy another vette. I've been vettless for about 7 years now.
Test drove a 95 with only 53K on it. I'm thinking I should maybe pass??
The temp went up to the last hash mark during a short test drive, when I got back I looked in the overflow and it was dry, except for some funky scum. Looked for a radiator cap, there was none??? Is there a radiator cap somewhere?
Also, the tranny fluid was a brown color with a reddish tint. Also not good.
I'm obviously concerned about this, thinking I should pass. Anyone disagree? I should note that the car ran strong, even got a little sideways going into second gear (automatic).
Clarification here: By last hash mark, I mean 3/4 towards hot, not full scale hot. Shouldn't it remain around mid-scale on the gauge?
The car was only running for 5 minutes or so. I went WOT through first gear only twice.
Also, what all should I be looking at when shopping for these C4 cars? Any help is appreciated.
Yes, it was a private party. If it was an actual dealership I would've felt better.
Radiator cap is on the surge tank, passenger side just in front of the firewall. Empty overflow tank can be a problem or just very poor maintenance. Fans don't even come on until 227* and 236* by design, so yes, the C4s run hotter than most cars. Have you read up on the LT1/4 engines?
I don't like not having a regular radiator cap to inspect the inside the radiator.
Not unusual for the Analog gauge to hit 3/4. Especially if your pullin power, the real question is what did the digital gauge get up to!
I wouldn't be all that concerned about the cooling system, other then doing some badly needed maintenance. The real concern is what shape is the tranny in? Did the fluid smell burnt.
I thought I had, but I obviously have some more to learn. Shouldn't the analog gauge read about mid-scale? Especially since I only ran it for literally 5 minutes? Like I said, I only went WOT twice, and only through 1st gear.
Shouldn't I be concerned about the dry overflow tank? Only a little bit of scummy crud in it??
As far as the tranny fluid smell - it wasn't a particularly strong smell, but wasn't a normal smell either. The color was definitely off - no question about that.
Why is it that 80% or more of people never change the tranny fluid? They'll do the oil religiously, but never the tranny, radiator, rear diff, etc.
Did the guy drive it before meeting you?
Having it run around 3/4's of the gauge is normal. It freaked me out when I first saw this, but the fans don't come on till around then. When the car is out of stop and go, it will probably drop a decent bit.
Cooling system can be cleaned but the trans would worry me, It's been neglected. Usually when the trans fluid is that color and you change it you soon end up loseing a clutch pak.
The overflow tank was like that on mine and did a complete flush. I cleaned out the stuff in front of the radiator(you get to that from under the front of the car). After that was done I took a air hose and blew out any dirt in and around the radiator and condenser and it runs at factory temps even on hot days. The trans you may want a shop to check that out for you.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
