Tire Manufacture Date
Could anyone pleas tell me where the date manufactured is located on these tires:
Goodyear EMT F1 Eagles.
Just cant seem to locate it on my 2002 Coupe.
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
The last 4 digits after the DOT stamp ... the first two are the week while the last two are the year
http://www.tirerack.com/tires/tirete...jsp?techid=11&
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
You bet ... I just bought a set of used tires that had almost no tread wear, and I was sure to check the date code (just a few years old).
I forgot to mention that the DOT stamp is usually (always?) only on one side, and that's likely the "inside" sidewall, so you have to crawl underneath or pop the wheel off the car to find it.
Last fall I bought a pair of ET Drags from Jegs. One was dated 7-09 and the other one 4-11. They were very good as far as swapping them out for 2 new ones dated 9-11.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Here is John
