315's 17" on c4 what do you think?
To Mr Shakedown. I'm considering 315's on all 4 corners also. I was hoping you could tell me the specs of the rims you have on the front. Also how does that effect your turning radius? When you went to the larger tire/wheel combination did you have to get an alignment, or speedometer adjustment? Any info would help me out, thank you.
Rob790 (11-24-2020)
I also find that it doesn't track any more on the road except my alignment isn't set for road crown so I get a slight pull to the right when on a heavily crowed road. I only seem to have it when on local roads as highways are wide enough and slight enough not to notice.
On my '92, I run GS rims all around. 315's fit in the back, no problem. Variances of tire width by manufacturer/model might make it rub a little. That will also depend on if you have lowered it. (They will still fit, but odds of rubbing the inside are higher.)
I have run 315's race tires on the front, mounted on 9.5" rims. They fits, and no loss in turning radius. (Why did it do this? -free tires, and didn't have two more 11" rims.)
As others have mentioned, check the offset. I seem to remember the 87's and earlier can run the actual ZR-1 offset without modification. '88-'96 need the 50-56mm offset
Always good to check the alignment with a new set of tires. (more so for us living with bad roads) A lot cheaper that burning up a set of tires.
Yeah 10.5 minumum and a good ZL 1 offset ! I have a pair of 315 B F G Drag Radials I run .
The only problem I'm aware of is if you run large tires and drive a lot you need to get alignment or risk rear bering failure !
The cars were not designed for that much meat and of course it throws off alignment and causes stress on componets like bearings.
Me I don't drive much with them on !
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
#33
#39
Rohn's is the only one with an earlier enough model year....but offset isn't listed. I'm guessing 36's or maybe spacers?
FWIW, I think the OP should consider his question hasn't been answered yet. Maybe you'll just have to mount them and see!
#40
Ah, to the point then . . . It depends on the offset. If you use '88-'96 rims, you will need spacers, as offset for 87 and earlier is different.
'88-'96 - 56mm offset (a few were 50mm)
'84-'87 - 36-38mm offset
ZR-1 factory 11x17 - 38mm
