Corvette C4 How To Videos
Just found this , special thanks to paintballoo7 (dogfish246) , and other guys
1. How To InstallC4 Corvette Rear Hatch Weatherstrip
2. How To ReplaceC4 Corvette Sunvisors by Mid America Motorworks
3. How To Installa C4 Corvette Hood Emblem
4. How to changethe headlight motor gear in a C4 Corvette
5. '90-'92 CDMTuner Receiver Box Removal
6. CorvetteHeadlamp Motor Removal and Repair 88-96 Willcox Corvette
7. How to: ChangeOil in a Corvette [HD]
8. HeadlightActuator Repair Kit
9. How to: Changea Fuel Pressure Regulator
10. How To: WaterPump Replacement
11. Underneath aCorvette [HD]
12. 1995 C4Corvette Front End and Hood Removal
13. CorvetteHeadliner Repair
14. How to InstallFender Stripes on a C4 Corvette
15. How to changeplugs and wires on the C4 Lt1
16. How to gap aspark plug (for our C4 specifically)
17. 1986 C4Corvette Alternator Replacement
18. 1986 ChevroletCorvette C4 Roof Panel Stripping
19. C4 CorvetteCutaway Replace Battery
20. How to"turn off change oil light" on c4 corvette & open stuck hood
21. How to replacethe fog lights
22. How to changethe battery on a C4
23. C4 CORVETTE WEATHER STRIPPING REPLACEMENT,HATCH
24. C4 CORVETTE WEATHER STRIPPING REPLACEMENT, ROOF
25. How to install the automatic antenna bypass switch in a C4 Corvette
26. 1984 corvette tail lights and removal
27. C4 CORVETTE WEATHER STRIPPING REPLACEMENT, DOORS
28. CORVETTE C4 DOOR PANEL REMOVAL
29. How To Remove Corvette C4 Valve Covers - Driver side
30. How to manually turn over a Corvette C4 engine
31. REAR HUB BEARING REPLACEMENT
31. CHARGING CAR A/C - C4 CORVETTE
32. FINDING AN A/C LEAK on a Car Pro Style - C4 CORVETTE
33. C4 Corvette Climate Control Codes
34. The below 11 videos are in post #68
How to Modify & Improve The Air Box Lid On A Corvette C4
Targa Top Headliner Repair - Corvette C4
1988 Corvette C4 Right Headlight Motor Repair
Corvette C4 Left Headlight Motor Repair
How to Remove and Replace a Radiator - Corvette C4
How to Remove Car Seats & Car Seat Cushions - Corvette C4
How To Remove, Paint & Restore Interior DoorPanelsCorvetteC4
How to Remove and Change an Alternator - Corvette C4
How To Change A Distributor Cap & Rotor Cap On A Corvette C4
How to Change the Oil & Oil Filter on a Corvette C4
Big thanks to GAS&GEARS GARAGE
How To Install C4 Corvette Rear Hatch Weatherstrip
How To Replace C4 Corvette Sunvisors by Mid America Motorworks
How To Install a C4 Corvette Hood Emblem
How to change the headlight motor gear in a C4 Corvette
'90-'92 CDM Tuner Receiver Box Removal
Corvette Headlamp Motor Removal and Repair 88-96 Willcox Corvette
How to: Change Oil in a Corvette [HD]
Headlight Actuator Repair Kit
How to: Change a Fuel Pressure Regulator
How To: Water Pump Replacement
Underneath a Corvette [HD]
1995 C4 Corvette Front End and Hood Removal
Corvette Headliner Repair
How to Install Fender Stripes on a C4 Corvette
How to change plugs and wires on the C4 Lt1
How to gap a spark plug (for our C4 specifically)
1986 C4 Corvette Alternator Replacement
http://www.youtube.com/watch?v=omLtl5HFN-w&list=UUBryJ7r8NzF2371EGuDEiag&index= 22
1986 Chevrolet Corvette C4 Roof Panel Stripping
C4 Corvette Cutaway Replace Battery
how to "turn off change oil light" on c4 corvette & open stuck hood
how to replace the fog lights
How to change the battery on a C4:
The following 6 users liked this post by Mohammed_z:
BET VETTE (02-09-2024),
confab (04-21-2019),
partimegolfer77 (08-08-2021),
Phil stock 91 (08-06-2017),
ron59 (10-23-2017),
and 1 others liked this post.
canadabob123 (08-11-2020)
I'll be doing this soon. Good video. Nice to know I need to remove all the trim before I get started and I would have never found that screw behind the halo light.
thunder1951 (01-28-2016)
great weatherstrip video! found this on the sidebar http://www.youtube.com/watch?v=Iavcz...eature=related
skip to 1:50 to see the '85 vette go from 96mph to 146 in 2 seconds!
Great video on hatch back weatherstripping replacement. Would be nice to be able to find some videos for the other weatherstripping.
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Just saw this one posted on You Tube - How to remove the dash-mounted CDM tuner receiver box.
http://www.youtube.com/watch?v=-z7A2OtdRIM
Specifically the 4 letters words and band-aids.
I studied the ones I found for pulling the door panels to replace the weatherstrip around the doors. Once the door panels are off (at least for my 1990), swapping out the door weatherstrip (I bought the weatherstrip from Wilcox) was a snap.
I'll be doing the doors this weekend. I found a posting on the forum thru a Google search that had great pictures for the door stripping. The hatch is getting done tonight so I will put that video to the test.
What was the search topic. I have tried to find some info but keep coming up short. The weather stripping on the doors of my 92 is starting to come apart.
Here is the jump:
http://forums.corvetteforum.com/c4-t...al-w-pics.html
I used the Wilcox Corvette main door weatherstriping. Good stuff. $44 for each side.
