Corvette C4 How To Videos
#62
#66
It is a very common problem due to the pressure regulator check valve lowers the pressure and the core is prone to partial clogs. Both my hoses were hot and I dismissed it because both hoses were warm to me. The core was partially clogged.
Fixed now couldn't be happier.
#67
I have an 89 vette and the climate control outside temp is stuck on 49. It is a different setup than the one in the video. Will searching the codes work the same on mine/
Just found this , special thanks to paintballoo7 (dogfish246) , and other guys
1. How To InstallC4 Corvette Rear Hatch Weatherstrip
2. How To ReplaceC4 Corvette Sunvisors by Mid America Motorworks
3. How To Installa C4 Corvette Hood Emblem
4. How to changethe headlight motor gear in a C4 Corvette
5. '90-'92 CDMTuner Receiver Box Removal
6. CorvetteHeadlamp Motor Removal and Repair 88-96 Willcox Corvette
7. How to: ChangeOil in a Corvette [HD]
8. HeadlightActuator Repair Kit
9. How to: Changea Fuel Pressure Regulator
10. How To: WaterPump Replacement
11. Underneath aCorvette [HD]
12. 1995 C4Corvette Front End and Hood Removal
13. CorvetteHeadliner Repair
14. How to InstallFender Stripes on a C4 Corvette
15. How to changeplugs and wires on the C4 Lt1
16. How to gap aspark plug (for our C4 specifically)
17. 1986 C4Corvette Alternator Replacement
18. 1986 ChevroletCorvette C4 Roof Panel Stripping
19. C4 CorvetteCutaway Replace Battery
20. How to"turn off change oil light" on c4 corvette & open stuck hood
21. How to replacethe fog lights
22. How to changethe battery on a C4
23. C4 CORVETTE WEATHER STRIPPING REPLACEMENT,HATCH
24. C4 CORVETTE WEATHER STRIPPING REPLACEMENT, ROOF
25. How to install the automatic antenna bypass switch in a C4 Corvette
26. 1984 corvette tail lights and removal
27. C4 CORVETTE WEATHER STRIPPING REPLACEMENT, DOORS
28. CORVETTE C4 DOOR PANEL REMOVAL
29. How To Remove Corvette C4 Valve Covers - Driver side
30. How to manually turn over a Corvette C4 engine
31. REAR HUB BEARING REPLACEMENT
31. CHARGING CAR A/C - C4 CORVETTE
32. FINDING AN A/C LEAK on a Car Pro Style - C4 CORVETTE
33. C4 Corvette Climate Control Codes
How To Install C4 Corvette Rear Hatch Weatherstrip
How To Install C4 Corvette Rear Hatch Weatherstrip - YouTube
How To Replace C4 Corvette Sunvisors by Mid America Motorworks
How To Replace C4 Corvette Sunvisors by Mid America Motorworks - YouTube
How To Install a C4 Corvette Hood Emblem
How To Install a C4 Corvette Hood Emblem - YouTube
How to change the headlight motor gear in a C4 Corvette
How to change the headlight motor gear in a C4 Corvette - YouTube
'90-'92 CDM Tuner Receiver Box Removal
Corvett CDM Tuner Receiver Box Removal and Repair 1990-1992 - YouTube
Corvette Headlamp Motor Removal and Repair 88-96 Willcox Corvette
Corvette Headlamp Motor Removal and Repair 88-96 Willcox Corvette - YouTube
How to: Change Oil in a Corvette [HD]
How to: Change Oil in a Corvette [HD] - YouTube
Headlight Actuator Repair Kit
Headlight Actuator Repair Kit - YouTube
How to: Change a Fuel Pressure Regulator
How to: Change a Fuel Pressure Regulator - YouTube
How To: Water Pump Replacement
How To: Water Pump Replacement - YouTube
Underneath a Corvette [HD]
Underneath a Corvette [HD] - YouTube
1995 C4 Corvette Front End and Hood Removal
1995 C4 Corvette Front End and Hood Removal - YouTube
Corvette Headliner Repair
1986 Corvette Headliner Repair - YouTube
How to Install Fender Stripes on a C4 Corvette
How to Install Fender Stripes on a C4 Corvette - YouTube
How to change plugs and wires on the C4 Lt1
How to Change the Spark Plugs and Wires in a Corvette - YouTube
How to gap a spark plug (for our C4 specifically)
How to Gap a Spark Plug - YouTube
1986 C4 Corvette Alternator Replacement
http://www.youtube.com/watch?v=omLtl5HFN-w&list=UUBryJ7r8NzF2371EGuDEiag&index= 22
1986 Chevrolet Corvette C4 Roof Panel Stripping
1986 Chevrolet Corvette C4 Roof Panel Stripping - YouTube
C4 Corvette Cutaway Replace Battery
C4 Corvette Cutaway Replace Battery - YouTube
how to "turn off change oil light" on c4 corvette & open stuck hood
how to "turn off change oil light" on c4 corvette & open stuck hood - YouTube
how to replace the fog lights
How to Replace a Fog Light in a C4 Corvette - YouTube
How to change the battery on a C4:
How to Replace a Battery in a C4 Corvette - YouTube
C4 CORVETTE WEATHER STRIPPING REPLACEMENT, HATCH - YouTube
C4 CORVETTE WEATHER STRIPPING REPLACEMENT, ROOF - YouTube
How to install the automatic antenna bypass switch in a C4 Corvette - YouTube
1984 corvette tail lights and removal - YouTube
C4 CORVETTE WEATHER STRIPPING REPLACEMENT, DOORS - YouTube
CORVETTE C4 DOOR PANEL REMOVAL - YouTube
How To Remove Corvette C4 Valve Covers - Driver side - YouTube
How to manually turn over a Corvette C4 engine - YouTube
REAR HUB BEARING REPLACEMENT - C4 CORVETTE - YouTube
CHARGING CAR A/C - C4 CORVETTE - YouTube
FINDING AN A/C LEAK on a Car Pro Style - C4 CORVETTE - YouTube
C4 Corvette Climate Control Codes - YouTube
#68
How to Modify & Improve The Air Box Lid On A Corvette C4
Targa Top Headliner Repair - Corvette C4
1988 Corvette C4 Right Headlight Motor Repair
Corvette C4 Left Headlight Motor Repair
How to Remove and Replace a Radiator - Corvette C4
How to Remove Car Seats & Car Seat Cushions - Corvette C4
How To Remove, Paint & Restore Interior Door Panels - CorvetteC4
How to Remove and Change an Alternator - Corvette C4
How To Change A Distributor Cap & Rotor Cap On A Corvette C4
How to Change the Oil & Oil Filter on a Corvette C4
gpierce (09-06-2018)
#70
Hi, I was wondering if you knew how to replace the turn signal bulbs on a '85? I have been searching the internet and to no avail I have found nothing. The light still works but the left front and left rear lights do not blink when I turn the signal on. Any help would be appreciated. Thank you.
#76
1987 Chevy Corvette
Hello, I just joined the Corvette Forum and If you need help working on your car I might be able to help you out. I just rebuilt my L-98 motor and I installed a cold air intake and dual exhaust system with no catalyst. I went .010 over on the piston rings with the stock pistons. I replaced the radiator, new electric fuel pump and water pump. The timing chain was worn out too so it was replaced too. I installed a shift kit in the transmission for firmer shifts.
#78
Here's a tip for somebody. The outside door trim on early 91s are bolted on with 7 studs I think it is while late 91-96 has a stud at each end of the trim and snaps in the middle. I destroyed one thinking it had snaps in the middle. And to get this early trim off the entire interior of the door has to come apart. This was on my ZR-1 which was built in Oct. the door trims the Zs and base cars.
