Corvette C4 How To Videos
Old 03-20-2012, 03:17 PM
ejscarfo
ejscarfo's Avatar
I didn't see that one. This is the one I found. http://forums.corvetteforum.com/c4-g...therstrip.html
I just needed to know where the pins were to determine if the door panel needed to be removed. Looks like I can't escape it so I'm replacing the window motors while I'm in there too.
Old 03-20-2012, 07:23 PM
Old Ben
Old Ben's Avatar
2017 C6 of Year Finalist
Putting these two links togeather gets the job done. Very, very helpful when photos show the way.
Old 03-20-2012, 08:26 PM
jim spitzer
Support Corvetteforum!
jim spitzer's Avatar
St. Jude Donor '12
That made it look easy to change the under dash CDM but it was not. How do I know because that was my car. Now the charge for that labor was well worth it. 100.00 I took the car over to longwood fl. and had the CDM removed for repair along with 1 speaker amp. Then the next week I went back for the reinstall and to finish the video
Old 03-21-2012, 10:28 AM
ejscarfo
ejscarfo's Avatar
Yup! I just installed the rear weatherstripping and after seeing the video, it went without a hitch. Someone had already changed it out I think because the yellow glue wasn't dried out like it should of been for a 27 year old car.
I soaked a rag in brake cleaner, ran it along the channel to clean it out. I didn't have to remove the halo lights because when I installed the new side pieces in the hatch, I never installed that last screw, I will go back and insert screws now that I know I won't be taking this apart again. Also, instead of removing both window lift shocks, I removed one at a time. I removed it, slipped the strip underneath and them reinstalled, did the same for both sides. I also started in the corners and worked my way around instead of folding it half to find the center. The whole job took 1/2 hour. No beer.
Old 06-20-2012, 09:24 PM
Mohammed_z
Mohammed_z's Avatar
Added : How to change the headlight motor gear in a C4 Corvette
Old 06-20-2012, 09:49 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Hopefully "YouTube" will avoid going public and keep great info like this available to everyone!
Thanks for the link "Mz"
Old 06-20-2012, 09:56 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is the video on the motor gear we did..
Headlamp motor removal and repair.. 88-96
Old 06-21-2012, 07:17 AM
Mohammed_z
Mohammed_z's Avatar
U welcome coach
Thanks willcox
Added :
how to change water pump
how to change fuel pressure regulator
how to change oil
Old 06-22-2012, 08:34 AM
Mohammed_z
Mohammed_z's Avatar
Title changed.
Old 06-24-2012, 04:28 AM
Mohammed_z
Mohammed_z's Avatar
Added : 1995 C4 Corvette Front End and Hood Removal
Old 06-24-2012, 06:59 AM
jim spitzer
St. Jude Donor '12
Originally Posted by summerst
Just saw this one posted on You Tube - How to remove the dash-mounted CDM tuner receiver box.
http://www.youtube.com/watch?v=-z7A2OtdRIM
that was the best 100.00 I spent on my car. That was the labor. And he made the video
Old 06-24-2012, 09:49 AM
CREWZIN
CREWZIN's Avatar
I replaced the rear window weatherstrip about two years ago. Messy job with all the yellow gook under the OEM strip. The new strip was/is so thick, I have to push with both hands to shut the window. No biggie. Thanks for the vids.
Old 08-08-2012, 07:21 PM
  #33
Mohammed_z
Mohammed_z's Avatar
up up up ,
Old 10-28-2012, 04:14 PM
  #34
Mohammed_z
Mohammed_z's Avatar
Added ,
Corvette Headliner Repair
Old 10-28-2012, 04:22 PM
  #35
Mohammed_z
Mohammed_z's Avatar
Added ,
How to Install Fender Stripes on a C4 Corvette
Old 10-28-2012, 07:35 PM
  #36
ghoastrider1
ghoastrider1's Avatar
just watched the sun visor one..heck, those guys dont even have grease under their fingernails. I want to know how to do that.
Old 11-17-2012, 09:57 PM
  #37
nhlighthouse
nhlighthouse's Avatar
Default video on how to replace 85 inside door panels
Does anyone have any links for a video on how to replace Interior Door panels for my 85 corvette ?...would be greatly appreciated!
thanks Mike
To Corvette C4 How To Videos
Old 11-29-2012, 03:15 PM
  #38
Mohammed_z
Mohammed_z's Avatar
thanks Mike
I couldn't find that, try to search the forum. Good luck
Old 11-30-2012, 12:00 AM
  #39
1944bagpiper
8th Gear
1944bagpiper's Avatar
Yeah.... My 93 passenger door panel top half is loose and I can't see how to put it in place without tearing it off. Any help?
Old 12-01-2012, 12:13 PM
  #40
dogfish246
dogfish246's Avatar
I have two more videos to add to the list!
How to change plugs and wires on the C4 Lt1
http://www.youtube.com/watch?v=Gr2oFPfAg90
How to gap a spark plug (for our C4 specifically)
http://www.youtube.com/watch?v=IuW3svdqKZM
Quick Reply: Corvette C4 How To Videos
