Fuel pump replacement 85
Old 02-25-2012, 02:55 PM
J W Drew
J W Drew's Avatar
Default Fuel pump replacement 85
Whats a reasonable price to have a shop replace the fuel pump in my 85.Thanks
JW
J W Drew is offline
Old 02-25-2012, 04:01 PM
mtnmanut
mtnmanut's Avatar
don't know what a shop would charge ,but its a pretty easy do it youself.simple tools not difficult at all. if you don't have a fsm a chilton or any other will guide you through it, and you can spend all day in the garage and sh'll think you worked your but off.
mtnmanut is offline
Old 02-25-2012, 04:14 PM
CAJUN C4
CAJUN C4's Avatar
Very easy job I'd say an hour Max taking your time.About an hours shop time $80.00 - $100.00
CAJUN C4 is offline
Old 02-25-2012, 04:33 PM
Joe C
Joe C's Avatar
the fuel pump went belly up in my 85 on a trip about 7-8 years ago, and i had to have the car flat bedded to a local chevy dealer for repair. seems to me they charged me about $240, parts and labor. hated to it, but i was better than 100 miles from home. my son just replaced his, and parts was around $60 and about 1 hour labor...
Joe C is offline
Old 02-25-2012, 06:12 PM
94c4er
94c4er's Avatar
Changed mine on my '94 pump was $80 and took less than an hour. Just remove your fill door (4 screws) remove the rubber boot disconnect the hoses and the dozen bolts and remove the unit. I would rather change the fuel pump than change the fuel filter!!
94c4er is offline
Old 02-25-2012, 06:45 PM
rodj
rodj's Avatar
http://forums.corvetteforum.com/c4-t...s-of-pics.html
rodj is offline
Old 02-26-2012, 09:27 AM
mikeb
mikeb's Avatar
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
mikeb is offline
Old 02-26-2012, 09:38 AM
WW7
WW7's Avatar
No reason for anyone not to do there own fuel pump. I would rate it as difficult as changing spark plugs.. Wilbro makes a nice kit that has a new gasket , new bolts, plus a full set of instructions ..About 1 hour.....WW
WW7 is offline
Old 02-26-2012, 11:15 AM
hitmanpty
hitmanpty's Avatar
That link is aweson. After that. No need to take the car to any shop
hitmanpty is offline
Old 02-26-2012, 12:50 PM
ch@0s
ch@0s's Avatar
I have a pump for sale if you buy it I will walk you through the install. Its very easy. It took me about 15 minutes to replace mine.
http://forums.corvetteforum.com/c4-p...placement.html
ch@0s is offline
Old 02-27-2012, 11:43 AM
F22
F22's Avatar
[QUOTE=94c4er;1580112375]Changed mine on my '94 pump was $80 and took less than an hour. Just remove your fill door (4 screws) remove the rubber boot disconnect the hoses and the dozen bolts and remove the unit. I would rather change the fuel pump than change the fuel filter!![/QUOTE]
Ain't that the truth!!! Nothing like being soaked in premium gasoline running down your arm, while you attempt to start the fuel filter fittings in the 'conveniently' located area that Chevrolet decided to put the late C4 fuel filter at...
F22 is offline
Old 02-27-2012, 10:49 PM
Frizlefrak
Frizlefrak's Avatar
You won't even get the second beer finished. 30 minute job. Do it yourself. Get a pump from Pep Girls, a basic socket set, a phillips screwdriver, and you're ready. If you hit a snag (which you won't) give us a shout and we will walk you through it.
Frizlefrak is offline
Old 03-01-2012, 01:21 PM
ejscarfo
ejscarfo's Avatar
Took me less time to swap out a fuel pump than change spark plugs in my 85.
ejscarfo is offline
Old 03-01-2012, 06:24 PM
Muffin
Support Corvetteforum!
Muffin's Avatar
Absolutely.
Muffin is offline
Old 11-29-2012, 06:50 PM
Jakez89
Jakez89's Avatar
this was a very helpful post. I had a Haynes manual for the car and lost it. Thanks for the post.
Jakez89 is offline
Old 11-29-2012, 07:51 PM
Jerry Roubos
Jerry Roubos's Avatar
Sent PM
Jerry Roubos is offline
Old 11-30-2012, 01:58 AM
J W Drew
J W Drew's Avatar
Thanks for all your sugestions. As for dong it myself, I have a REALLY bad back so all I can do is take this Vette to a shop. Now for those who say "if you can't fix it your self you shouldn't own a C4" I agree. But its not about money. When I was 25 I owned a C2 and when I was 30 I owned a C3. Not to mention I have raced Unlimited Hydro's and was a Pilot in the AF. Also owned a chain of equipment rental stores so I am mechanicaly inclined. Now that I'm 65 I plan on driving this C4 into the sunset and how sweet it is.
J W Drew is offline
To Fuel pump replacement 85
Old 11-30-2012, 10:57 AM
mtnmanut
mtnmanut's Avatar
TOURINGMIKE ; apparently posted a picture of the OP's pocket change.
mtnmanut is offline
Old 11-30-2012, 01:30 PM
aj1988
aj1988's Avatar
If you have a shop stool or bar stool you can do this sitting down. Everything is done at the filler door level.
The only thing that wasn't said is disconnect the battery before you start. I know you disconnect the plug before you take the holder out of the tank, but I am a wuss and not willing to take the chance.
Also get some type of pan to put the assembly into to keep from dripping gas on the car.
Good luck and I do understand the bad back. Just look at the floor and get out the drugs.
aj1988 is offline
Old 11-30-2012, 07:22 PM
Tact
Law Dawg Moderator
Tact's Avatar
CF St. Jude Co-Organizer
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
http://forums.corvetteforum.com/foru...s-or-more.html
Tact is offline
Quick Reply: Fuel pump replacement 85
