Question about 84 engine
I would say it is a dream as of now but ive decided I'll do anything to achieve that dream. As of now I have the car that's all. I'm going to wait until I have half of the money needed. So I will do without for awhile but it will be worth the sacrifice. If I'm lucky 15k will supply everything needed.
A reasonable engine build and Trans build set me back half of your 15K budget..
Alot of guys on here have seen projects that were started w/ good intentions, only to stall & never get finished. Then you have a vette that you can't drive & a bunch of parts, then you take a hit just to get rid of it all. My advice is to do a more reasonable project, esp. if this is the first time doing big mods, something that you can use your current engine,tranny, ect. You'll learn alot.
Pro Mechanic
Hopefully that doesn't happen But I'll try to get it finished on my vacation time so it doesn't drag out. If my cousin and I can get a week off together it's all finished. We swapped an engine out of a nissan car in one day. But it was plug and play no mods necessary. They make a dash that has analogue style gauges. So just get a panel identical to that for the gauges. When I start something I go until my body tells me to stop.
Newthread located in forced induction section. Decided to listen to a few members on the forum. Talked it out with a few others and came to the conclusion it is best to start off with something a little simpler than to invest so much time and money into one thing.
