Cruise Control Not Working
Old 01-31-2012, 09:07 PM
MikeIz 82VETTE
MikeIz 82VETTE's Avatar
Default Cruise Control Not Working
Hello guys, got a few questions and would appreciate any help i can get. thanks in advance!
Cruise control not working and wondering where i should start looking. is that a vacum issue or on C4's is it electronic?
thanks guys
Old 01-31-2012, 09:15 PM
Kmcoldcars
Kmcoldcars's Avatar
On my 1992 it is vacuum operated. What year is your Corvette? ALWAYS include the year as the C4 Corvettes are not always the same.
I would check the vacuum at the hose going into the cruise control unit. With the car running just pull the hose off the cruise unit and stick your thumb over the end of the hose. If you have vacuum you will need to look elsewhere. If you do not have vacuum you will need to find out where the leak is.
Old 01-31-2012, 10:16 PM
MikeIz 82VETTE
Sorry, it's a 96
Old 01-31-2012, 10:22 PM
jakers
jakers's Avatar
St. Jude Donor '06
Originally Posted by MikeIz 82VETTE
Sorry, it's a 96
Mike,
I fixed mine on my 94 by simply replacing the vacuum line. The old one had split. New one and it was fixed... .
Old 01-31-2012, 10:50 PM
MikeIz 82VETTE
Cool! i will check for that and hopefully it's a easy fix!
thanks!
Old 01-31-2012, 11:22 PM
Azriel
Azriel's Avatar
Mine too. What's the cruise control thingy look like?
Old 01-31-2012, 11:57 PM
Kris_K
Kris_K's Avatar
Mine stopped working recently too. The CRUISE light doesn't come on anymore either, would that be from a bad switch?
Old 02-01-2012, 04:22 AM
CorvetteSonntag
CorvetteSonntag's Avatar
thanks guys
This is a picture of my 87( i have no idea if it is even remotely the same as yours). look all the way at the bottom right and you'll see a rounded looking mechanism(its right above the battery) with a cable coming out of it and leading to the side of the throttle body. that is the cruise control mechanism.
hope that helps
Old 02-01-2012, 08:09 AM
markKlein
markKlein's Avatar
I didn't think there was a cruise light??
Old 02-01-2012, 08:55 AM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
There is no cruise light on the C4
You are correct.
Old 02-01-2012, 09:10 AM
Kris_K
Kris_K's Avatar
Now, I know it's been a while since I've used my cruise and I have a few different cars so I may be confused, but I thought I remembered seeing a CRUISE light in the dash of my 94 when the cruise was engaged.
UPDATE: I checked the owner's manual and no mention of a CRUISE light so I must have dreamt that one. Anyway, my cruise control definitely stopped working so I will just follow along and hopefully I solution will pop up.
Old 02-01-2012, 12:03 PM
Goldcylon
Goldcylon's Avatar
As stated there is no cruise on/off light. I wish there was so you know for sure its engaged at the switch level.
Reguardless another thing to look for beyond the vaccum line is the brake switch. If it is not centered on the top of the brake pedal arm cruise control will not engage. It must make contact with the brake arm. Also Cruise control can not set I believe below 20-25 Miles per hr.
Old 02-01-2012, 03:15 PM
jon1all
jon1all's Avatar
Where is this brake switch located? The cruise on my 88 also quit working a few months ago & would like to find this brake switch to see if it's the problem.
Do I need to remove the kick panel above the brake pedal to see/find it? What does it look like? Thanks!
Old 02-01-2012, 03:39 PM
Goldcylon
Goldcylon's Avatar
Its above your brake pedal you cant miss it. It needs to be centered on the brake pedal arm. No you do not need to remove the kick panel. Its really two switches with the electrical side normally the culprit
http://forums.corvetteforum.com/c4-t...-for-94-a.html
To Cruise Control Not Working
Quick Reply: Cruise Control Not Working
