Cheap ebay seat cover pics
these were 200 shipped,not perfect but better than before.hopefully more of the wrinkles will come out once it warms up out side.
IMG]http://i42.tinypic.com/xy9g6.jpg[/IMG]
Received 6,984 Likes
2015 C2 of Year Finalist
are the wrinkles caused by the foam being worn out?
Our seats are literally stretched around pre-formed foam. At several points, rings are punched thru the foam to grab the covers and pull them tight.
Yes, as foam deteriorates, it can let the cover sag. Upholsterers normally overstuff or replace foam when redoing seats. Overstuffing means they lay down 1/4-1/2" of foam on top of existing foam. Plus, they might add chunks here/there. The point is to fill out the cover so it's stretched tight -- void of wrinkles.
Some installers will also use a heat gun to pull fabric tight. I think a higher percentage like to overstuff to get their final result.
I take it these are the Iggy brand
do you have a link?
Top cushions look like you didn't pull the tension tight enough on the center bolster. I don't know how these covers work, but the OE units I bought 7 tears ago had tabs on both edges that a rod inserted thru. I then secured a hog clip on either side, and pulled the other taut. I doubt if warm weather will help it, but again, I ain't familiar with these type of covers.
For what you spent, they look OK.
Bottom cushions look good.
Doesn't look bad, there are a few other members on here that used those exact covers with great results!
lushdrunk
rob-cyn
lushdrunk
rob-cyn
I think those look great, especially for the price, not all of us can afford close to a grand for seats. Thanks for posting. What hog ring pliers did you use?
To those that used these how long ago did you do install them and how are they holding up
I may pick up a pair. Don't really like the iggee's I have on my seats now. I mean really, for 200 bucks... Not too bad.
