Erod ls3
#561
Got it smog checked today.
Finally found a local STAR station that would do it, so didn't have to take it back to the BAR Referee.
It's running fine.
I'm having an intermittent horn problem---sounds continuously & I have to disconnect the horns to get it to stop. Last time it happened I opened up the dash to check for shorts, per the shop manual, but the problem resolved itself & my tests were inconclusive.
I suspect it's a thermal problem either with the wiring, horn switch, or the original computer/security system. Only seems to happen when it's sitting in the sun, after I've been driving it.
Still waiting for GM to come up with a cruise control module for the EROD package. The GM engineer I was working with during the swap said they were working on one, but it hasn't been released AFIK.
It's running fine.
