Why 9.5" wheels with the Z51 package?
I'm researching tires for my '85's. 255 50r16 are unavailable at this time, but 245's are available and perfectly fine with me.
However, one of my cars has the Z51 package and, thus, 9.5" wheels. Mounting 245's on 9.5" wheels is way out of the tire/rim fitting ranges, and in the archives I have found posts that say that it's not safe, it will look funny, or that it can't even physically be done at all (although in one case it was actually done-- accidentally). So I probably won't be doing that.
I like the turbines/salad shooters and I do no competitive driving, so I could probably get a cheap set of 8.5" turbines to replace the 9.5's that are on there, but that brings up the question of whether there is any problem with using the 8.5's with the Z51, which is just a reflection of the question of why 9.5's were used in the first place.
Looking through the archives, I found this thread:
http://forums.corvetteforum.com/c4-g...y-z51-c4s.html
but there were only a few comments that addressed the question-- it mostly discussed the combinations of wheels on various years/packages. The only hint is that someone says you get better handling with the wider wheels.
So my questions are:
1. As a practical matter for my car, are there any issues with swapping stock base (8.5") turbines in place of the 9.5" Z51 turbines currently on my Z51-equipped '85? I'm guessing there is not, since I don't care if there is a slight decrease in handling (since I don't do anything competitive), but just wanted to check first.
2. Out of curiosity's sake, *would* there be any change in handling? Why were 9.5's part of the Z51 package, even though they came with the same tire size as the base package? I assume for better handling, but I don't know (due to my own ignorance) how wheel width would affect handling if the tire size is the same.
In this piece, tire rack says that:
So GM went outside the tire fitting range to do 9.5" wheels, so I assume there must have been some compelling reason for it-- but what was it? And if there is a rationale for it, would it not apply to justify 245's on a 9.5" wheel? Or is whatever benefit you get from a 255/9.5" combo lost if you push it too far with a 245/9.5" combo?
Many questions there, any insights appreciated.
Chevrolet has combined P255/50R16 sized tires on optional 16x9.5" rims (which are 0.5" wider than the 9.0" wide rim now listed for the size) on certain [i.e., Z51] Corvette models. While these applications have received the approval of the vehicle and tire manufacturers, staying within the approved rim width range helps assure that the tire's internal stresses are within its design parameters.
http://www.tirerack.com/tires/tirete...sp?techid=198&
Slingshot
Because the 255/50 VR 16" tires are no longer available. However, 245/50 VR 16" tires ARE available. This is what the OP is asking about....
I realize this, I was just unaware that the only size tire to fit those rims were the 255/50 VR16" tires. I do know that they fit other widths to 9.5" wide rims, that was my reason for asking.
Slingshot
For what it's worth, I have run 255/50 x16" tires on my 10" BBS wheels, front & back, for over 25 years now with absolutely no problems or ill effects. I have had no high speed related problems at all. The car handles like a slot car. What's more the BBS wheels are 36 lbs lighter than the OEM Corvette wheels.
I too am considering the 245/50 x 16" tires and would love to mount them on my 10" BBS wheels. Soooooo, while I do not know the answer to your question, I am very interested in a proper and knowledgeable response.
Z51 was the " Performance Handling" package intended for guys who wanted to race around corners in weekend;
hence the stiffer suspension and bigger swaybars , faster steering , etc.
I may have missed something, but Summit has a number of 255/50R16s available: http://www.summitracing.com/search/D...6/?Ns=Rank|Asc
Most are Drag Radials, but the BFG 97802s should work alright...
Had me excited for a minute, though!
Pro Mechanic
As a practical matter, there will be no issues. As a "handling" matter, there will also be no issues until you reach the absolute limit of traction on dry pavement...then you would notice (if you had very accurate measurin gequipment) an extremely slight reduction in maximum traction. Unless you're in a competition environment, you won't notice any change in "handling". Car will drive the same. Actually, in some cases the narrower tires will improve "handling" such as during straight line travel; the car won't pull/dart as much.
See above. No SOTP difference. They didn't come w/the same tire size; the 8.5" rim came with a 245/50 R16...1cm narrower. The Z51 came with the 255 width tire to achieve maximum possible lateral grip (at the time) for that chassis and price point.
Edit: Forgot to mention that this source says that only 255's were used on every c4 or handling package:
http://www.corvetteactioncenter.com/...usp_chart.html
If a 245 will fit safely on the 9.5 rim, and not look stupid...run them.
Otherwise, have you looked for a 265/45-R16? IF that exists, that would probably be the best solution.
Thanks.
The g-Force Sport is indeed the right tire, but if you try to put them in the cart it says they are currently not in stock and will have to be special ordered. It says they expect to ship on 9/20, but I think that's a mistake. BFG is not making that tire right now (at least as far as I know) and they will not be able to special order it.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Unfortunately there are no 275's for a 16" rim (except for some 70 aspect ratio truck tires).
pmihaltian has given me some hope that the 245's will work on the 9.5" rims, but if not, there is pretty much no tire other than the 255/50/16 for that wheel (at least none that make sense for me).
So I either decide to go for that, or I'll be in the market for some used 8.5" turbines since it appears there will be no problems using those on my Z51.
Thanks for the idea, though.
and the 16" rims as a option.
In the end ,all 51,000+ cars ended up with the 16" rims and 255/50 -16 tires.
IIRC it was specially developed by Goodyear for the C4 and the biggest tire available in the USA at the time
http://www.joby.se/corvette/div/corvette_wheels/
http://www.motorera.com/corvette/1980/vet84.htm
Pro Mechanic
Yep...as usual, you're right on.
I'm GLAD that the base wheel was never used.
Slingshot
That's interesting-- 255mm tires on a 10" (254mm) rim is even further out of spec than 245mm tires on a 9.5" (241mm) rim. If that's working (and you say it works well), then maybe it's not crazy to put 245's on my 9.5" rims? Do they look weird? Some say that kind of tightness will look ridiculous.
I do not know if the 245/50 tires would look the same or not.
@rodj-- Did you have any opinion about the wisdom of mounting 245's on a 9.5" rim? Way out of spec, but pmihaltian seems to have no problems with 255's on 10" (which is even worse). Just wondered what your opinion might be, but no problem if you were taking a pass on the question.
