Rear Rotor replacement on 1986 c4
You mean Axle nut, right? 200 ft lbs on rear axle nut. I bought a 3/4" drive torque wrench that goes to 300 specifically for this job. It should have been VERY tight...one of the main questions on here used to be "How do I remove my stuck axle nut?"
I guess it was a good thing because it came right off. So I need to torque it to 200. The wheel bearings are behind this correct. That will not effect the bearing being that tight.
Now set the parking brake, chock the wheels to be safe, and torque to 200 ft lbs. Lift car back up, remove wheel, install cotter pin.
Yep....it's funny (once it's fixed) to see previous owner's blunders. Ghetto rigging, damage, neglect....etc. It's a lot of fun to make it right again too. Very gratifying.
Just to be an azz, factory spec on that nut is 164 ft lbs.
Correct. And this is one of the few times I will tell you to ignore the manual. This has been discussed ad nauseum here over the last ten plus years. Torqueing to 200 has solved numerous issues of rear end noise...specifically a "clicking" on take off or backing.
I don't have my old Helms any more, but I believe on the early C4 the manual called for 164 on auto and 200 on manual.
Your bearing, your choice.
I know about the nut, and yes every time I torc it to "spec" it seems like it lasts about a week then it starts making rear end noise and I have to tighten it again.
So I went to torc it at 185 and if it happens again I'm goin to 200. Because it's true I do hear a lot of guys here with loose nuts, no pun intended, and that should not be happening.
