Pics of z06 wheels on c4
Old 05-15-2011, 11:48 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Old 04-23-2016, 11:01 PM
dargo042560
1st Gear
dargo042560's Avatar
Originally Posted by rob-cyn
Those look killler
i hope you can tell me if those tires and wheels will fit a 1995 c4 convertible and the size of them thanks .
Old 04-24-2016, 09:04 PM
pologreen1
pologreen1's Avatar
Yes if they are stock off set they fit. That fad has come and gone, but they still looked good on his car.
Old 04-24-2016, 09:52 PM
Not Red Rob
Support Corvetteforum!
Not Red Rob's Avatar
2023 C4 of the Year Winner - Modified
These were on my '02 Z06, fit like a glove....
Old 04-26-2016, 08:22 PM
92polo
92polo's Avatar
C6 Z06
Old 10-18-2016, 12:08 PM
DMITTZ
DMITTZ's Avatar
I know this is an older thread but pictures are fun so here's mine:
18x10.5 speedline C5 Z06 wheels on all 4 corners with 315's.
C4ProjectCar (08-28-2020)
Old 10-18-2016, 02:29 PM
QCVette
QCVette's Avatar
Originally Posted by DMITTZ
I know this is an older thread but pictures are fun so here's mine:......
My '96 had them when I bought it. These were cheap aftermarket ones that are no longer on the car, but it shows how they look. I like the stock painted ones or the '04 polished ones better.
kael
kael's Avatar
Finalist 2020 C4 of the Year - Unmodified
Your Vette year is > '87, right? Those look like high offset.
Old 10-18-2016, 02:34 PM
DMITTZ
DMITTZ's Avatar
Yes, it is a 1988. The stock wheels were 56mm offset and my C5 Z06 wheels are 58mm offset I believe so pretty close to stock.
Old 10-18-2016, 05:10 PM
MRPVette
MRPVette's Avatar
17s front 18s rear
Old 10-18-2016, 05:34 PM
kg4fku
kg4fku's Avatar
​​​​​​​[img]
I can't believe that doesn't rub. Please tell me that doesn't rub. I need to hear that doesn't rub.....
Old 10-18-2016, 05:48 PM
DMITTZ
DMITTZ's Avatar
They fit front and rear with out rubbing... before I put my vansteel/QA1 coilovers on the front, which required the front sway bar to be relocated forward which also moves it slightly closer to the wheel, which made it slightly rub at full lock so I added 15mm hub centric spacers on all 4 corners (cost about $50), that solved the problem and they don't rub now at all.
They were pretty tight though before the coilovers but they did fit on my car without rubbing (no spacers).
Old 10-18-2016, 06:26 PM
  #33
kg4fku
kg4fku's Avatar
Showed that to my wife and before I could even ask I got shot down.
Already spent my upgrade allowance for this Winter.
Always next year though......
Old 10-22-2022, 09:02 PM
  #34
v8_ranch
3rd Gear
v8_ranch's Avatar
Originally Posted by gkrynick22
Here are my stock C5 Gunmetal Z06 wheels on my car. By far my favorite wheels, 17's in the front and 18's in the back.
What year is your car? I need to get the right adapters for my 87. it had been facelifted to a 95 look, and had ~3/4" spacers on it for the Sawblades, but they used regular lug nuts that stick out way to far and the Z06 wheels also do not have near the recess for that as the saw blades... so, bummer for me, I will not be installing my newly acquired Z06 wheels quite yet.
Quick Reply: Pics of z06 wheels on c4
