91 fuel pump relay location?
"Inside the passenger compartment, under the dash." FSM
That would be in the vicinity of under the glovebox IIRC.
location?
This is what my fsm says also. However when I remove the carpeted panel there are no relays in this configuration. I found a box full of 5 relays unmarked. Is this the correct relays? They are also smaller than the relay I bought to replace. Please Help?
St. Jude Donor '09-'10, '14
What do you mean smaller? They are a square looking box thingy just like in the picture. Maybe they gave you the wrong one. Also IIRC those relays are interchangable.
as I said they are smaller. (1 inch square) The one I bought is about 1 1/4" square. And they are not in a line like the fsm shows. They are in 2 rows. 3x3. So which is the fuel pump relay?
In any case why would you not want all those items working?
1 Post
Not to bring back a thread from the dead,but,I rather do this than make a new one ( proof that I searched the topic ). When I search this questions I get two answers,one says in the engine bay to the left of the brake boost. The other is inside the car under the dash on the driver side and now I'm reading passanger side. Is there a difference from model to model ?
Jbarr91 (07-03-2023)
