C4 heater core replacement
Old 03-31-2011, 07:19 PM
ginoglad
4th Gear
ginoglad's Avatar
Default C4 heater core replacement
I am trying to replace the heater core on my 85. Have dash out and able to pull out bottom of cover. Can't get top screws of cover off. Any suggestions appreciated. This is a real "bear".
Old 03-31-2011, 07:31 PM
engle1147
Support Corvetteforum!
engle1147's Avatar
You could have left the upper dash installed.
You just need to remove them by "feel" since they cannot be seen easily. Leave those upper 2 screws out after you get ready to button it up....it will not cause a problem.
Did my heater core and it took about ~10 hours (9 of those seemed like they were spent messing with those 2 upper screws)to get the job totally done...not hard...just takes time.
Old 03-31-2011, 08:29 PM
ginoglad
4th Gear
ginoglad's Avatar
Thanks for the advice and encouragement.
Old 03-31-2011, 08:36 PM
WW7
WW7's Avatar
If you get a couple of these Flex 1/4" extentions in different sizes it will make the job a lot easier. Trust me on this.....WW
This is a great set to have....
http://www.amazon.com/Flexible-Exten...&n=228013&s=hi
Old 03-31-2011, 08:49 PM
ginoglad
4th Gear
ginoglad's Avatar
Thanks for the tip. You make it seem common sense, which is a good thing.
Old 04-01-2011, 10:14 AM
AGENT 86
AGENT 86's Avatar
Ya, read this thread
http://forums.corvetteforum.com/c4-t...ol-delima.html
To C4 heater core replacement
Quick Reply: C4 heater core replacement
