my 1990 with 6speed runs great for half an hour then idles very rough before it dies. If left for an hour or more it starts and runs normally for another half hour before it starts all over again. During rough idle it won't throttle up past an idle. Squirting starter fluid into the plenum during rough idle lets in run smoothly. Fuel pressure and spark check out fine. Tech 2 diagnostics at chevy showed stored code 51 no pulse and 13 02 sensor.
