Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C4 Corvette Discussion not covered in Tech Sponsored by
Marc Heitz Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-07-2011, 08:20 PM   #1
mynoot
Junior Member
Default I am leaking large amounts of transmission fluid 1994 with photos
Thanks for taking the time to help me out.
I am leaking large amounts of transmission fluid, and have no idea what to look for. I have attached a few photos for you to see how much is leaking in just the last 5 days. The car was moved back little and you can see the new pool forming father back and that is from just the last few hours
As you can see in the second photo there is more fluid about to drip off the transmission pan.
Click the image to open in full size.
Thanks for your help!
mynoot is offline   Reply With Quote
Old 03-08-2011, 09:35 AM   #2
anciano
CF Senior Member
anciano's Avatar
Not from the pan,and not from the cooler lines at the radiator, so I'd say it's probably where the cooler line(s) enter the transmission housing. Or one of the lines has a hole.
anciano is offline   Reply With Quote
Old 03-08-2011, 09:48 AM   #3
Larry/car
CF Senior Member
Looks like your torque converter is draining into the transmission which overfills the pan and this overfill drains out the vent. I think there is a check valve to prevent this. You can test this by driving the car, the leak shouldn't show up for a few days.
Larry/car is online now   Reply With Quote
Old 03-08-2011, 10:02 AM   #4
84vette96
CF Senior Member
84vette96's Avatar
I would look at the servo cover. The o ring may have started leaking. The servo is a round cover half way up the side of the transmission.
84vette96 is offline   Reply With Quote
Old 03-08-2011, 10:21 AM   #5
zr1fred
CF Senior Member
Generally speaking, when you have a trans leak after sitting awhile, and not when running, it is a case seal. Usually the dip stick tube, or possibly the shifter shaft, possibly the front pump seal. What happens is as the trans sits, fluid will drain back into the pan, causing the level to rise over the above mentioned parts (or others), this is very normal. When the seals are bad you get leaks. That's why you check the transmission fluid when it is running. Are you sure the transmission isn't over filled to begin with. You need to make sure its not leaking when running, which would generally be a pressure leak
zr1fred is offline   Reply With Quote
Old 03-08-2011, 01:41 PM   #6
mynoot
Junior Member
Well thanks for the relays guys, this care sat unran for 5 years and the pan was almost dry, I filled it with just under 8 quarts of fluid in the last 2 weeks and I know it holds around ~6. at this point I cannot drive the car around but I have run it trough all the shifting points and got the temp up to ~230 for around 30 min on a few occasions and did not notice a large amount of fluid leaking when running is any. It seams to leek a little all the time and more when it has sit for a few days.
So what would be best to do? Go get seal replacements for the pan, shifters servo cover and ….. and just replace them all in one go and see if it helps? Its about time to drop the pan and clean it out anyway.
Old 03-08-2011, 01:56 PM   #7
kimmer
CF Senior Member
kimmer's Avatar
Before you just start replacing things clean up all the mess and look for the leak then proceed.
kimmer is offline   Reply With Quote
Old 03-08-2011, 03:14 PM   #8
mynoot
Junior Member
Thanks for the advice I just jacked the car up and cleaned it up a bit and took some new photos. I think I have located the leek and I took photos for you guys to see for your self. These where taken just a few seconds after wiping down the location and you can see the transmission fluid starting to pool up on the bottom of the bolts.
If you guys need more photos feel free to ask I am happy for any help I can get.
Old 03-08-2011, 04:26 PM   #9
MyFirst90coupe
CF Senior Member
MyFirst90coupe's Avatar
Interesting. Mine leaks at the same spot .... Not sure if it's the pan gasket or torque converter leaking.
MyFirst90coupe is offline   Reply With Quote
Old 03-08-2011, 09:24 PM   #10
mynoot
Junior Member
Well looks like ill be pulling the pan tomorrow and see if that helps, ill get it all cleaned out as after 5 sitting years and 120k miles it needs some love. If not ill update the forum and see what you guys think should be done next.
Old 03-08-2011, 10:06 PM   #11
zr1fred
CF Senior Member
Dry it off, rinse it with carb cleaner, and look very carefully. A lot of times you will have a leak on the top (at least above the pan) and the fluid will run around the edge of the pan making you think its the pan gasket. Most of the time, it won't be the pan gasket. Your picture shows the area just under the filler/dip stick tube.
Old 03-09-2011, 12:29 AM   #12
mynoot
Junior Member
Well I am having a small issue getting in around the pan to see/clean how would I go about replacing or inspecting the other points?
Old 03-09-2011, 08:45 AM   #13
zr1fred
CF Senior Member
Get a rag and wipe it down good. Then get a can of carb cleaner and spray the entire area within 2" of the pan and wipe dry. Get a good flashight and mirror and look closely all around anything that has a seal. With that much of a leak, you should be able to see it, though you might have to add a quart or so of fluid to replace what has already leaked out. Believe me, it's no fun to spend $50 or so in fluid and filter kit replacing the pan gasket and then find out it is still leaking. You might try tightening the bolts on the pan. Don't over tighten, they should be just slightly more than snug. I use a wrench with a short (4") handle. If tightening the bolts doesn't help, it's probably not the pan gasket.
Old 03-09-2011, 12:19 PM   #14
mynoot
Junior Member
Well ill head out right now and try to get that done, before I drive out and buy new parts. I think ill try cleaning around the tras and then sticking bunch of paper towels up into the side if the leek is there I would think they would get wet over time.
thanks for the help
Old 03-09-2011, 12:59 PM   #15
Railroadman
CF Senior Member
St. Jude Donor '09-'10-'11-'12
Railroadman's Avatar
That could be it. You can't put 5 lbs of excrement in a 3-pound bag!
Railroadman is offline   Reply With Quote
Old 03-09-2011, 02:33 PM   #16
mynoot
Junior Member
Quote:
Ah yes I would have explained better, I have had to put 8 in to keep it full meaning it has leaked over 2
Old 03-09-2011, 02:36 PM   #17
mynoot
Junior Member
well I started working on tightening up the pan bolts they where in fact way under tightened time will tell if this is the issue. I tightened them to manual specs. I all so put a large about of paper around the other seals to see if they may be the leak. Sadly I slipped when working on one of the bolts and smashed a finger so I may have to wait a little bit before doing any more work.
Old 03-09-2011, 03:20 PM   #18
mynoot
Junior Member
Quote:
Well after a few hours you can see the leak is showing on the paper but only near the pan. The rest of the paper near the seals was dry. I pulled out the old paper and put in new to see if the result are the same. Sadly I only got to tighten up a few bolts before I smashed up my hand ill get under there again soon and do the rest and see if that fixes the issue.
Old 03-09-2011, 03:21 PM   #19
Railroadman
CF Senior Member
Maybe you will get lucky and the loose bolts will be the answer.
Old 03-10-2011, 01:03 PM   #20
mynoot
Junior Member
Ok well I have a disappointing outcome but expected the pan is not the leaks source its ether the cooling lines or the filler tube line. I am hopeful I can fix this issue without dropping the transmission. My next step was going to be to remove the exhaust covering the side of the transmission. Any ideas other then that?
Reload this Page Leaking transmission fluid and battery is draining if car is left sitting 94 vet
Tags
battery, car, draining, fluid, leak, leaking, leaks, left, pan, servo, sitting, tranmission, transmision, transmission, years
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
