What is the correct rear tire size?
1994
Tire Rack says 285 40 17,
Currently on car is 275 40 17, and the tires from another forum member for sale are 275 40 17.
My corvette is getting ready to be sold and need some newer (not new) tires for the rear but if the correct size is 285, then I will keep looking.
I just had a new set of Continental Tires installed on my 1994 which are 255/45/17 front & 285/40/17 rear per door sticker indication. I have the stock saw blades and believe they're 8.5 width front & 9.5 width on the rear.
It varied a bit across the years of the C4..
Personally I wouldn't put anything less than 285 on the rear of these cars. Ideally mine would be 295, but no-one sells a 17 inch tire that size. If anyone does let me know
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
As long we have these threads there will always be something for us to read.
Or look at the "dish" on your front and rear wheels. If the dish is the same, you probably want 275's all around. If the fronts have slightly less dish than the rears, you want 255/285's.
Does your car have the original wheels?
it all depends on whether your car has 17x9.5 wheels all around (in which case the correct factory size is 275/40/17) or if it has 17x8.5 up front & 17x9.5 out back (in which case the correct factory sizes are 255/45/17 up front & 285/40/17 out back).
if you do have 17x9.5 all around though 285/40/17 all around works (& looks) good too! That's what I run & love 'em! But it is not 'factory'.
oh yeah & btw... If you have 255/45/17 up front I would not put 275/40/17 out back... The 255/45 is about half an inch taller than the 275/40 & would probably be noticeable & weird looking to have taller front tires.
the 285/40 & 255/45 match up almost perfectly...that is why the factory chose those sizes for the base suspension cars (ie, the ones with 8.5 front wheels).
1 Post
1994
Want to give a little more information than that?
Eakster wanted to know if anyone sells a 295 series in a 17" that would fit.
Tire Kingdom does not have any 295 series tires listed in a 17" size.
And a 275 is not wider than the 285 either. At least not in any tire specs I have looked at.
Goodyear Eagle GS-D3
285/40-17: Section Width = 11.3" , Tread Width = 9.9", OD = 26.1"
275/40-17: Section Width = 10.8" , Tread Width = 9.4", OD = 25.7"
There is no magic formula for tire sizes as long as they are in ballpark and fit the rim correctly. A 275/40 tire converted to inches is 10.8 in. wide and has a sidewall height of 4.3 in. A 285/40 has a tread width of 11.2 in. and sidewall height of 4.49 in. So you are talking about a difference of less than half an inch in tread width and less than a fifth of an inch sidewall height. Those are differences in contact patch and overall height that varying tire pressures can cause, and how many can tell us their actual tire pressure right now to within 4-5 pounds (no fair peeking)? Not to mention the fact that centrifugal force at high speeds can increase a tire's circumference significantly (a lot more than 1/5 in) so in that case the 275 might be optimum.
The engineer that decided a 285/40 was the "correct" size was sitting in a cubicle next to the engineer that said you should tighten your oil filter to 22 lb/in (or something) -- just a number somewhere close to the middle of the allowable range, and in full awareness that real-world tire conditions such as temperature, load, speed and a host of other factors have an influence on the "perfect" number.
It's a Chevy for cryin' out loud -- not the space shuttle.
kdr3 (02-04-2023)
1 Post
Why would 275/40-17 be the "preferred" size on a car that came with 285/40-17?
Tire manufacturers differ.
