I replaced my front Y pipe with one with out precats :)
WHen you replace the front Y pipe with one without Pre Cats, and also remove the Main Cat, will you have any problems with the Oxygen sensor operating correctly ? I am also considering running duals all the way back. Somewhere I think I read on the forum that removing the cats woudl cause Oxygen sensor problems. I have a 87 with only one Oxygen Sensor on the left pipe.
8Valve
8Valve
You can get a cat-less front Y-pipe at most of the Corvette Parts houses. Here is one with a high output main cat:
http://www.ecklers.com/corvette-y-pi...1986-1991.html
I just ordered that today, and Ecklers has a 15% off coupon code on their site.
