Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C4 Corvette Discussion not covered in Tech Sponsored by
Marc Heitz Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-30-2011, 08:54 PM   #1
Jim Nichols
CF Senior Member
Jim Nichols's Avatar
Send a message via AIM to Jim Nichols
Default How Do You Replace C4 Shocks
Does anyone have a link to how to replace the shocks on a 91 Coupe? I have checked the tech section without finding what I am looking for. Appreciate any help.
Jim Nichols is offline   Reply With Quote
Old 01-30-2011, 09:09 PM   #2
zr1fred
CF Senior Member
It's pretty straight forward unless you have the adjustables, than it's just $$$$. Was there a specific problem you ran into?
zr1fred is offline   Reply With Quote
Old 01-30-2011, 09:28 PM   #3
JrRifleCoach
CF Senior Member
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
JrRifleCoach's Avatar
Location: Hey! lets give all our money to the government Peoples Republik of Kalifornico-
You need to access the top bolt of the rears under the carpet.
BTW use lots of PB blaster on those bolts.
JrRifleCoach is offline   Reply With Quote
Old 01-30-2011, 09:29 PM   #4
jrzvette
CF Senior Member
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
This will get you started
http://www.corvette-guru.com/uploads...rontShocks.pdf
jrzvette is offline   Reply With Quote
Old 01-30-2011, 09:35 PM   #5
96GS#007
96GS#007's Avatar
The Factory Service Manual is your friend.
Just my respectful opinion...if you're asking such a basic question, I highly recommend you take the car to a shop.
__________________
Jim
'96 Grand Sport #007
A few mods here and there
96GS#007 is offline   Reply With Quote
Old 01-30-2011, 09:37 PM   #6
zr1fred
CF Senior Member
I think the 91 uses a bracket, adapter, plate (pick one) that bolts on to the top of the rear shock and then bolts onto/into the frame with two 13mm bolts.
Old 01-30-2011, 09:37 PM   #7
96GS#007
96GS#007's Avatar
There are no bolts you access by removing the carpet. You remove the two bolts that secure the mounting plate to the frame via the wheel well.
__________________
Jim
Old 01-30-2011, 09:53 PM   #8
JrRifleCoach
CF Senior Member
Quote:
Sorry. Thought the late C4's had a single nut on the top. Read somewheres where the top nut was easier to access from the top?
Maybe it was a mod...
Old 01-30-2011, 11:39 PM   #9
96GS#007
96GS#007's Avatar
Only if you use a hole saw and cut thru the top of the frame rail after cutting thru the body. Many people with dedicated track cars will do that in order to more easily adjust Koni adjustable shocks.
__________________
Jim
Old 01-31-2011, 12:03 AM   #10
RockG
CF Senior Member
Support Corvetteforum!
RockG's Avatar
Ok, instead of the one bolt from shock, there are two bolts facing upward holding the bracket remove those two bolts and the bottom part of shock and it comes out. Then you remove that two bolt bracket and put it on your new rear shocks before it goes back in.
RockG is offline   Reply With Quote
Old 01-31-2011, 12:08 AM   #11
Frizlefrak
CF Senior Member
Frizlefrak's Avatar
When you look at it, the how-to will be pretty obvious.
Frizlefrak is offline   Reply With Quote
Old 01-31-2011, 07:58 AM   #12
jon0108
CF Senior Member
jon0108's Avatar
Quote:
jon0108 is offline   Reply With Quote
Old 01-31-2011, 08:09 AM   #13
dwblindref
CF Senior Member
dwblindref's Avatar
Default 4 hours
If you are handy you can do the complete job in less than 4 hours. If you are not handy have a friend come over that is handy and buy a case of beer and have at it.
dwblindref is offline   Reply With Quote
Old 01-31-2011, 10:46 AM   #14
c4cruiser
CF Senior Member
c4cruiser's Avatar
There were two different upper shock mounts. The early C4's used a bolt that went thru an eye on the top of the shock. There was a saddle-type mount to insert the eye of the shock and the bolt went thru the mount, thrut he eye and a nut on the bolt. Either way, you have to raise the car and remove the rear tires. The large bolt at the bottom does need some effort to remove and the shock has to be slid off the mounting pin.
The later C4's had a separate upper mounting bracket that attached to the shock. Those shocks attached to the bracket similar to the way the front shocks are attatched on the upper part. The bracket then was inserted into a hole on the underside of the frame rail and bolted in with two small bolts.
The front shocks are pretty straight forward, a nut on top of the shock rod for the upper end and two bolts that hold the lower end of the shock to the lower control arm. You don't even need to raise the front of the car to replace the front shocks. The nuts on the lower bolts are easily accessible with a long socket and the nut on the shock rod can be removed with a box-end wrench.
c4cruiser is offline   Reply With Quote
Old 01-31-2011, 01:07 PM   #15
92ragtop
CF Senior Member
92ragtop's Avatar
Quote:
It's not hard to do. However, one thing to be aware of, which I just encountered, is that the upper half of the top bushing (that sits up inside the frame rail, can be swollen. On mine I really had to struggle to get it out of the hole in the frame.
Torque on all bolts and top studs is 20 ft lbs. The big nut on the lower rear is torqued to 60 ft lbs.
92ragtop is offline   Reply With Quote
Old 01-31-2011, 01:58 PM   #16
Frizlefrak
CF Senior Member
Frizlefrak's Avatar
Quote:
Plan on doing very little wrenching and a lot of drinking. Start an hour before superbowl and still not miss kickoff.
Old 01-31-2011, 02:24 PM   #17
c4cruiser
CF Senior Member
c4cruiser's Avatar
When the lower shock nut on the rear suspension is tightened, the car has to be on the ground at ride height. Snug the nut up and roll the car back and forth a couple times so the suspension settles and then tighten to the spec.
Old 01-31-2011, 03:59 PM   #18
Joe B.
CF Senior Member
Joe B.'s Avatar
Shock replacement is pretty straightforward, right, but here's a small dilemma. In general the top nut should be tightened to expand the bushing out to the dia. of the washer. The previous post said 20 ft. lbs. on the nut. Replacement washers are a harder urethane than the stock rubber ones so maybe 20 ft.lbs. isn't enough to properly expand the bushing. Comment? One other point, the stock bushings have a nice male female arrangement to them to keep them centered on the stud. Replacements will probably be the generic donut type. If the stockers are in perfect condition, as mine were, can or should they be reused?
Joe B. is offline   Reply With Quote
Old 03-10-2011, 07:33 PM   #19
Rocket-J
CF Senior Member
Rocket-J's Avatar
Default 94 fx3
Is this the same on the rear with FX3 actuators? Remove the two bolts and it all slides down out of the hole? I seen nothing when I pulled up my carpet.
__________________
2012 Carlisle Blue, 3lt Grand Sport 6 speed manual with Black and Grey interior. Cyber Grey stripes. Comp. Grey wheels.
Drive it like it is the last lap of the Daytona 500.
Rocket-J is offline   Reply With Quote
Old 03-10-2011, 08:12 PM   #20
92ragtop
CF Senior Member
92ragtop's Avatar
Quote:
Yup. You unbolt the plate and then pull the shock assembly out of the hole in the frame. If the bushings are swollen, you may need to use some persuasion.
Reload this Page How Do You Replace C4 Shocks
Tags
1968, 1984, 1996, 91, c3, c4, change, corvette, lower, mount, rear, remove, replace, replacing, shock, shocks
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
