To convertible owners who use the hard top.
I picked up my car yesterday. The hard top is currently on the car and I was curious as to how long people leave these on and if it will damage the soft top.
Thanks.
Thanks.
Cruise-In V Veteran
St. Jude Donor '06
I would want to occasionally take the hard top off and bring the soft top up, but I would not feel bad about leaving the hard top on for three to five months - that was, after all, the original design intention.
Thanks. It is something else. It has a 406 and it is a terror.
I am looking forward to having a lot of fun with it.
Nothing wrong with leaving the hardtop in place for months at a time. You do need to be careful in folding the soft top and putting a clean towel where the plastic window folds is a good idea.
Obviously, keeping as much moisture out of the interior as possible is a big help. If the soft top is white, it's vinyl, if it's black or tan, it will be cloth.
Did you get the OEM Torx ratchet and the small ratchet for the rear encapsulated bolts that are in the locating pins??
Cruise-In V Veteran
St. Jude Donor '06
HT on, mid dec thru march, it's a good idea to use a clear strip to protect the paint under the HT, other wise you risk marring the paint.
I sometimes use the HT in August when it is really hot in Texas
I've only had my hardtop on the car since October so won't know how it's faired until spring. I did use a pillow for the soft top and the paint protecters for the paint.
The hardtop has other benefits too. With the hardtop installed, the car is quieter inside. Resonance from aftermarket exhaust systems is reduced.
If the hardtop is properly installed, the car actually becomes stiffer than a coupe. It should also allow 'vert owners to use their cars for track days/HPDE's if there is a requirement for roll bars for 'verts. The hardtop has an internal "halo bar" that is similar to the coupe and the large steel attaching brackets that attach to the top and the B-pillars providing the strength and some roll-over protection.
