Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C4 Corvette Discussion not covered in Tech Sponsored by
Marc Heitz Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-25-2010, 10:05 AM   #1
89 corvette
CF Senior Member
89 corvette's Avatar
Default Want to make my vette faster, just not sure were to start? Some help Plz
Hey everyone, I have a 1989 corvette l98 bone stock when it comes down to the drivetrain. The only mod is some corsa mufflers, and I'm actually looking to get louder so I might do a muff delete and a resonator delete? I want to make my vette fast but not willing to sacrifice AC and stuff like that because my vette isn't a garage queen, I give myself any excuse to take it out and toy with some of the ricers we have out here in NYC. So I would appreciate if any of you guys could help me out without doing a full rebuild
89 corvette is offline   Reply With Quote
Old 12-25-2010, 10:23 AM   #2
Flame Red
CF Senior Member
Flame Red's Avatar
How fast you want to go? How much $ do you have to get there?
Most important thing is to set the above parms and then come up with a plan. It is important to come up with a plan otherwise you will just end up throwing parts into it and not acheiving your objective and end up wasting $ and effort.
Generally speaking, and engine is a pump, the more air and fuel in and out the more power. Until you hit the next weakest part of the system. Once you set the above parms, look at intake, heads, cam and exhaust. Even if you have to save up and execute your plan over a long time, the results in the end will be better and cheaper.
Flame Red is offline   Reply With Quote
Old 12-25-2010, 10:35 AM   #3
corvetteronw
CF Senior Member
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Support Corvetteforum!
corvetteronw's Avatar
Here is some great advice:
http://temp.corvetteforum.net/c4/vader86/
corvetteronw is offline   Reply With Quote
Old 12-25-2010, 10:39 AM   #4
Jim Nichols
CF Senior Member
Jim Nichols's Avatar
Send a message via AIM to Jim Nichols
For about $350.00, you can replace your Y-pipe on the L-98. The power and sound increase is noticeable. What you are doing is getting rid of the two pre-cats. This is legal in everywhere except the People's Republic of California. I have a mechanic who did the install for $50.00 and he kept the three cats to sell. A stainless steel pipe directly thru the main cat can also help, but I would never recommend that. (wink-wink). You will feel the response immediately and the sound improves.
http://www.ecklers.com/corvette-y-pi...1986-1991.html
Jim Nichols is offline   Reply With Quote
Old 12-25-2010, 11:00 AM   #5
89 corvette
CF Senior Member
Well to start out right now I have about $1000 to play with, and as far as how much faster I want to go, well I want to be in the 350+ hp range As far as the rest of the car I already have upgraded brakes and tires and as soon as I have enough power I will be doing the suspension. The y-pipe mod sounds good and I will be looking more into that, so is there anything else? Like that hypertech chip Iv seen all over ? And how about those miniram intakes I see forsale all over?
Once again thanks all you guys, I'm defently going to put alot more thaught into it, thanks to you guys
Please keep in mind I still want my vette to be reliable on all this process.
Old 12-25-2010, 11:20 AM   #6
John A. Marker
CF Senior Member
John A. Marker's Avatar
Forget the chip.....snake oil . with corvetteronw....read Vader's site...several times.
As indicated above, how much do you want to spend. Improve intake and exhaust is a good start. If you don't want to do heads or can't, then go for roller rockers. It might also be time to change out the injectors.
You will get the most performance with heads and cam.
__________________
1995 LT1 6 speed - stock.
SOLD to son ** 1985 Coup -ZZ4 balanced, LPE 74211 , AFR 180 heads, SuperRam base, runners & plenum, cut out air box, K & N , power coupler, 52MM TB, March pulleys, AFPR, Accel injectors, Walbro FP, 1.6 RR, chip by TJWONG, 160 stat, cut back plugs, 8.5MM MSD wires, custom camber-brace,TRANSGO shift kit, 2400 stall converter, cross drilled rotors, SS brake lines, VBP camber rods, IAS Edelbrock shocks, exhaust, Magnflow cat, 3.07 gears, 13.2 @107.2 MPH in 1/4
John A. Marker is online now   Reply With Quote
Old 12-25-2010, 11:21 AM   #7
89 corvette
CF Senior Member
Corvetteronw I just read alot on that site and all I can say is WOW. Changed alot of what I was thinking, thanks alot I'm defently keeping that site.
Thanks again CORVETTERONW
Old 12-25-2010, 11:24 AM   #8
twin540
CF Senior Member
twin540's Avatar
Start saving some money, you're going to need it.
twin540 is offline   Reply With Quote
Old 12-25-2010, 11:24 AM   #9
89 corvette
CF Senior Member
From vaders sight I think I'm going to start with the full exhaust then the k&n cut out. How much would I be looking at if I took it to a local shop to do the exhaust setup, taking out the precats and everything?
Old 12-25-2010, 12:05 PM   #10
PLRX
1995 and 1996 Vettes
St. Jude Donor '09-'10-'11-'12-'13
PLRX's Avatar
Establish your HP goals and limits. You already have a fantasy now you need the materials.
1. Cash
2. Credit Card
3. Paypal
4. Summit Racing
5. Other Vendors
6. Mailing Address
7. Garage
8. Tools
9. Digital Camera
10. Wife or Girl Friend
11. Post pictures of #10
For all questions about the L98 there are tons of posts.
This is the trick:
Click the image to open in full size.
Good luck, have fun and drive it.
PLRX is offline   Reply With Quote
Old 12-25-2010, 12:28 PM   #11
89 corvette
CF Senior Member
sounds good, Thanks alot guys ill be heading to the muffler shop as soon as they open lol
Old 12-25-2010, 02:06 PM   #12
corvetteronw
CF Senior Member
Cruise-In VIII
I went with some muffler eliminators on the 87 I used to have. Took them off and sold them after 6 months or so. They were nice at idle and at low RPMs but were just too socially nasty when the RPMs got up there. My wife refused to ride in the car.
I was able to find a catless Y and a Magnaflow high flow cat along with a new rear Y and Magnaflow mufflers. It still sounded good but was much easier to live with.
I now have another L98 and am going with the same setup.
Check out www.corvettecentral.com for their exhaust systems. Oh yeah, purchase a new O2 sensor and have the muffler shop install it while they have it up on the rack, Those things always fail when the car starts to get a few miles on it.
Another thought. With the Obama administration making more noises about greenhouse gasses I don't think this is the time to run without a catalytic converter. You could end up getting fined or having to take the car off the road if the smog ***** bust your arze.
Old 12-25-2010, 02:29 PM   #13
Mohammed_z
CF Senior Member
Mohammed_z's Avatar
Mohammed Al Nasri
Dont waste money on mufflers and catback , they dont make your car faster .
Do the basic boltons , cam , heads , Nitrous shot (if you really want go fast).
and tires.
Mohammed_z is offline   Reply With Quote
Old 12-25-2010, 06:59 PM   #14
58VetteBoy
CF Senior Member
58VetteBoy's Avatar
Do you think you could get a fair amount of money for your '89 if you sold it? The reason I ask is since you are looking for 350+ hp it might be cheaper to just sell yours and find a ZR-1 or a Callaway. Just my two cents.
58VetteBoy is offline   Reply With Quote
Old 12-25-2010, 08:29 PM   #15
ch@0s
CF Senior Member
ch@0s's Avatar
Quote:
Awful advise.. Click the image to open in full size.
There are plenty of people making that kind of power and it's not hard.
ch@0s is online now   Reply With Quote
Old 12-25-2010, 08:36 PM   #16
90sundevil
CF Senior Member
90sundevil's Avatar
Sell your car and buy a C6 Z06.
90sundevil is offline   Reply With Quote
Old 12-25-2010, 09:28 PM   #17
cuisinartvette
CF Senior Member
St. Jude Donor '05
Youre looking for almost 100hp youll need Nitrous a blower or a head/cam/intake package to get there. Save about 5k min then go to town. You can get 350 (realistic)-400rwhp with a LTR setup but youll be spending quite a bit to get there. THen upgrade the trans then, then, then...$$
cuisinartvette is online now   Reply With Quote
Old 12-25-2010, 10:09 PM   #18
Calderone
CF Senior Member
Calderone's Avatar
Are you going to do the work ?
It makes a lot of difference if you are or if you are taking it to the shop
Not sure if you are mechanicaly inclined but its VERY important
that you know what are you doing and why,if not you can lose a lot of money
if you hang with the wrong mechanics.
I strongly suggest you to buy John Lingenfelter's on Modifying SB Chevy Engines
and the Factory service manual ! You'll love it !
http://www.amazon.com/John-Lingenfel.../dp/155788238X
Calderone is offline   Reply With Quote
Old 12-25-2010, 11:54 PM   #19
Dyno Don L.
Junior Member
Look here:
www.socaltpi.org
Dyno Don L. is offline   Reply With Quote
Old 12-26-2010, 09:33 AM   #20
FOURSPEEDVETTE
CF Senior Member
FOURSPEEDVETTE's Avatar
Quote:
Why even respond with something like this?
FOURSPEEDVETTE is offline   Reply With Quote
Reload this Page Want to make my vette faster, just not sure were to start? Some help Plz
Tags
05, 1989, 89, 98, c3, c4, corvette, costs, faster, lot, make, money, sound, spending, vette, wanna
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
