You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
What have you done to prevent potential tire flat spots during winter storage? I'm located in the midwest so storage can last from early November through April. Car will be stored in an unheated garage. I do have large heavy duty vinyl mats that cover the entire garage cement floor. I also have all season tires installed, which are a harder compund, so hopefully they wouldn't get affected as much.
In Florida I don't worry about winter storage but if I did I would jack the car up put blocks under the suspension arms just thick enough to keep the tires from touching the ground. This will keep the suspension loaded as it normally is with the tires off the ground. This set up will allow you to start the car and run thru the gears provided your storage spot has sufficient ventilation.
Flatstoppers Tire Supports work well. I've also had good luck putting a section of old carpet under each tire to prevent them from coming into contact with the cold concrete in our garage.
All I do is put about 5 extra pounds of air in mine. Never had a problem with flat spotting and mine is in storage maybe a little longer than yours
with Sweetsies...last winter I just overinflated about 10 lbs and had no problems. Besides wouldn't a "flat spot" get worked out after a few miles of driving on a warm road anyways?
astepup said that
Depends. Flatspotting can be temporary (the tire will round out as driving warms it up) or in the most severe cases, permanent (in which the tire's memory effectively destroys its ride quality).
A flatspot's severity is often a function of the tire size, internal structure, load, ambient temperature and time.
Low aspect ratio tires have less sidewall flex due to their short sidewalls and much of their load carrying capacity is absorbed by the deflection of their wide footprints.
The tread compounds and firm, nylon reinforced internal constructions used on high performance and high speed rated tires are more susceptible to flatspotting.
Heavy loads and too little air pressure in the tires (underinflation) will allow them to deflect more where they come into contact with the ground. This allows even more deflection, increasing the severity of the flatspotting.
Cold ambient temperatures make rubber compounds stiffer, increasing their tendency to flatspot.
The longer tires remain stationary, the better they remember the position in which they were last parked. Tires on vehicles stored on the ground for many months can be permanently flatspotted.
The best solution is to drive the car a few times in the winter. It doesn't have to be very often, once every couple weeks will do it. Here in the mountains of West Virginia it gets cold, but I can always get the car out a couple times a month..I never do the storage thing.....WW
Quote:
I put an extra 10 PSI and park on some scraps of carpet ...Works for me
thick rubber gym mats under tires...the good thick ones. One square is enought o cut down for four tires. About $50.
google wright fitness equipment in birmingham, al . they are the biggest supplier in the U.S.
