Battery for key fob
Old 03-30-2002, 09:34 AM
Shawn93PoloConv
Shawn93PoloConv's Avatar
Default Battery for key fob
I cannot find a battery to replace the old one in the key fob. The local GM dealer didn't have one and I have checked a few places. It's a Sanyo CR2450. It has a recessed lip around the outside which is important as another replacement battery without that recessed lip would not fit. Help!
Old 03-30-2002, 10:23 AM
Ron04,02,96,64
Ron04,02,96,64's Avatar
Default Re: Battery for key fob (Shawn93PoloConv)
Shawn, Lowe's or Home Depot generally have all the "CR" series batteries. I've found the correct one for my 96 and for my Grand Cherokee FOB's at one or the other.
Old 03-30-2002, 10:25 AM
Ron04,02,96,64
Another thought for you. I've also seen the CR series batteries in K-Mart where they sell watches.
Old 03-30-2002, 11:20 AM
Shawn93PoloConv
Default Re: Battery for key fob (Ron99,96,64,57)
Thanks, I'll check out those places today. :)
Old 03-30-2002, 12:02 PM
carter200
carter200's Avatar
Walmart Superstores have them, too :seeya
Old 03-30-2002, 12:15 PM
GTB
GTB's Avatar
Default Re: Battery for key fob (carter200)
I replaced mine with a Panasonic I got at Radio Shack. Perfect fit!
Old 03-30-2002, 12:22 PM
squeaky g
squeaky g's Avatar
Just got one at Walgreens, but the locking, unlocking is still inconsistant. Any ideas?
Old 03-30-2002, 12:57 PM
Ron04,02,96,64
Default Re: Battery for key fob (squeaky g)
I had one FOB where inside the case where the "button" makes contact, the very small solder connections of the mechanism were broken causing intermittent function.
Old 03-30-2002, 04:41 PM
Shawn93PoloConv
Radio Shack struck out. They had the right number but didn't have that little bevel around the (+) side of the battery. No fit. Sent me to a batteries place but was closed. Sigh. Keep looking.
[Modified by Shawn93PoloConv, 3:43 PM 3/30/2002]
Old 04-01-2002, 09:56 AM
Arctic Trooper
Arctic Trooper's Avatar
Try this site: http://www.tnrtechnical.com/ . It's the only place I found that has the original Sanyo battery with the bevel.
Old 04-01-2002, 01:36 PM
scorpion
scorpion's Avatar
had the same problem. could not find the right battery.
but if you carefully put the battery w/o the little bevel in, it will work.
Old 04-01-2002, 04:30 PM
Goody
Goody's Avatar
Default Re: Battery for key fob (scorpion)
I got an energizer one at my local PX and it worked just fine. Didn't pay that much attention. :seeya
Old 04-02-2002, 09:29 AM
turbota
turbota's Avatar
I found mine in CVS
Old 10-21-2018, 07:11 PM
jabromitis
3rd Gear
jabromitis's Avatar
Default Battery doesn't fit 94 Key FOB
Ok simple cheap fix. We all know the key fob back then has a dl2450 sanyo battery with a lip to fit under clip. They do not make them anymore, so what I did was take my Dremmel and grind a low spot where each clip holds. Wellah! fits perfectly. Cost me nothing. ENJOY!
Old 10-23-2018, 03:14 PM
slipup
slipup's Avatar
I buy mine in boxes of 6 from Amazon.
To Battery for key fob
Quick Reply: Battery for key fob
